2004 Audi A4 3.0
Backstory - My fans used to come on and were probably on high the whole time. When I would turn the car off they would sound like a jet engine spooling down. At the time I had no idea that it was a sign of troubles ahead. Now the fans don't come on at all. Here's what I've done:
*Replaced the Coolant Temp Sensor
*Replaced the Fan Control Module
*Checked that the fans were ok by jumping 12v to them. Both came on fine.
*Checked the relay (219). Put power to it and verified that it had continuity. Checked out fine.
After all this the fans still don't come on. With the A/C on LO (full blast) the smaller fan kind of twitches like it's trying to come on but doesn't quite make it. The other fans does nothing at all at temp.
One thing that I haven't been successful at locating is a fan temp switch which is supposed to be located on the lower radiator hose. I can't seem to locate it on my vehicle. There's a plastic housing that looks like it has a place for a sensor but it's blocked off. And it looks like it came from the factory that way. When I purchased the Coolant Temp Sensor from the dealership, they had a hard time determining whether my vehicle had one or not, even when looking it up using the VIN.
Also, the fan control module I bought was a super cheap one. It may very well be that I got a piece of junk, but before I spend the money and time on replacing it, I want to be sure that I've exhausted all other possibilities.
So, are all 3.0's equipped with a Fan Temp Switch (or similar name) and if not, what sensor tells my cooling fan (not A/C) to come on?
Thanks in advance!
