Results 1 to 15 of 15
    Junior Member Two Rings Nick-B7's Avatar
    May 01 2015
    Rhode Island
    What is this sensor?
    Why is there oil inside the harness of this sensor?
    Mar 01 2016
    San Diego/CA
    Maybe accumulated due to engine oil vapor. Wipe it and check after few days. Any leakage in the nearby area, like vacuum pump?
    Mar 24 2013
    Oakdale, CT
    Its the N205 control valve. It controls oil flow for use with variable valve timing on the exhaust cam. Generally, when oil leaks into the connector, it's time to replace it since it will probably fail and throw a CEL soon.
    -Adam
    Jun 17 2013
    jersey city nj
    And that sensor costs some $$$$ too
    Oct 24 2015
    Perth, WA
    My respray thread
    Jun 17 2013
    jersey city nj
    On a side note, If you need a timing chain cover for some reason. If you buy the cover from the dealer it will come with a new 205 valve already ed on the cover
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by vce1232000 View Post
    Not if you shop around
    https://www.amazon.com/Variable-Sole...&keywords=n205
    -Adam
    Jun 17 2013
    jersey city nj
    Damn thats cheap. Wunder if its a knock off brand thou. You know how knock off works sometimes....
    Oct 24 2015
    Perth, WA
    Wouldn't be a knock off at ECS i very much doubt. Says Genuine and I doubt they would risk their reputation.
    *edit* apologies I saw the other post just now.
    My respray thread
    Mar 24 2013
    Oakdale, CT
    It works fine so far. I've been running it since the beginning of the year.
    -Adam
    Jun 17 2013
    jersey city nj
    Was it a oe-oem part
    Mar 24 2013
    Oakdale, CT
    Looked identical to the part it replaced if that means anything. Same markings and everything.
    -Adam
    Veteran Member Four Rings klrider44's Avatar
    Aug 20 2014
    Doylestown PA
    I bought one super cheap off eBay and I haven't had any issues. I replaced mine preemptively. Had a code for it but turns out the connection was just loose. Had a bit of oil on it so I just replaced it anyway.
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    Knock off lasted 1700 km. Sure it was $20 but you'll end up paying full price for a new unit or you'll get lucky and a friend will sell you a used unit for cheap. -1 for the cheap knock off. Not worth the money saved.
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    Yep, N205 valve...just replaced mine with the OEM from ECS. Mine poured oil out of it when I disconnected it and I was also getting a P0016 code when I drove the car hard. I'm hoping this was the culprit...
