Results 1 to 3 of 3
    May 29 2012
    Cedar City Utah
    Help with persistent misfires
    I have a 2007 q7 that has had a misfire problem for a while now. It runs and idles great but when the rpm gets up around 4500 the the check engine light starts to flash.
    When I check the codes it says there is a missfire on cylinders 1, 4 ,2 ,8, 6, and 7. The funny thing is those cylinders missfire when I'm accelerating, but if im decelerating and down shift to slow down then cylinders 3 and 5 start to misfire. I took it to the dealer a while back they replaced the fuel pump, the fuel filter, the spark plugs and coils and an intake runner actuator to no avail. I asked them about cleaning the carbon off the intake valves but all they offer is a some sort of cleaner they spray in the intake while the engine is running so I ordered the parts and did it myself. Still have the same missfire. If anyone has any ideas that would be very helpful thanks
    Junior Member One Ring mikeA602's Avatar
    Feb 16 2016
    2007 RS4
    KS
    try checking your PCV my c5 4.2 misfired at idle and i got a few flashing CELs also was like a $80 part
    Established Member Two Rings staypuft's Avatar
    Jan 27 2013
    Dirtbikes!
    Lehigh Valley, PA
    I gotta put new plugs in mine often to keep it idling nice.
    +1 on the PCV
