    Veteran Member Three Rings Velox's Avatar
    Mar 30 2016
    S4
    Oranjestd
    Motor mount, clunk on acceleration, but no fault code?
    Hi I've been hearing a big clunk when accelerating and more idle vibration
    I did the motormount "test" the engine lifts very high when applying light throttle with brake and I hear the clunk sound.
    So i'm guessing motor mounts right?
    but I have no motormount fault codes?
    Is it possible for a motor/engine mount to fail but without giving faut codes/cel?
    Or does my registered vcds lite not read these codes?
    s4 b6 2005
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    Yes mine failed without a code or even juices coming out. I hear a clunk everything I accelerate from stop. Very annoying!
    Mar 30 2016
    S4
    Oranjestd
    Ok thanks for your quick reply
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    get you some 034... they are awsome, no extra roughness... keeps the girl where she belongs, throw in a snub while your at it... dont forget the resistors
    half the price of OEM and you WILL feel the difference ;)
    PAST
    2004 Audi (B6) S4 4.2L
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167
    Current
    2015 Audi (B8.5) A4 2.0T P+ Sline ECS-Luft-Technik Intake System/Air Scoop v2/Silicone Intake Tract Set with turbo muffler delete, GFB DV+ VTA Performance Blow-Off Valve, JHM FMIC/ECU and TCU (Automatic 8 Tip Quattro) Stage 2 tunes. Cosmetic RS4 Honeycomb Mesh Front Grille and Fog Light Vent Grilles
    Mar 30 2016
    S4
    Oranjestd
    Quote Originally Posted by TarlCabot View Post
    I actually just ordered those :) . Forgot the snub though
