Results 1 to 2 of 2
    Established Member Two Rings CarlWeasly's Avatar
    May 25 2015
    Rockford, IL
    PSA - To those that have had the drivers floor board soaked or wet
    Just a quick PSA for those with drain issues ending up with a wet carpet. You should consider pulling the carpet asap, mine got bad after a string of storms and there's mold everywhere where the foam soaks up the water. I highly recommend you pull the carpet and soak up all the water you can and clean everything thing you can. Stay healthy brothers
    Drivers side
    And passengers side for reference
    Sent from my Nexus 6 using Audizine mobile app
    2000 A4 1.8TQM - k0mpresd stage 2 tune - Some other stuff
    Build thread here
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    Yup. I drilled a 7/32 hole in the floor pans on each side to drain any water too.
