Results 1 to 17 of 17
    Established Member Two Rings Pandito bandito's Avatar
    Jul 19 2016
    Missouri
    Replaced battery now mmi not working
    Hi all new to the 6 series so need a Lil help if possible. My brothers car 05 A6 3.2 quattro. Left something plugged in overnight an killed the battery. Replaced the battery just fine an mmi worked at first after having to power it back on manually but now it won't come on at all? Any thoughts or helpful suggestions?
    Sent from my XT1585 using Tapatalk
    Active Member One Ring Raul_Arias's Avatar
    Oct 01 2016
    León / Spain
    You test reseting MMI
    Enviado desde mi SM-G850F mediante Tapatalk
    Jul 19 2016
    Missouri
    Quote Originally Posted by Raul_Arias View Post
    Resetting how?
    Oct 01 2016
    León / Spain
    You push at the same time as in picture.
    Jul 19 2016
    Missouri
    OK an is that with the mmi off screen blacked out right?
    Oct 01 2016
    León / Spain
    MMI has to be ON
    Jul 19 2016
    Missouri
    Yeah I can't even get the mmi to power up at all. Hey the opening splash screen then just goes black
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    Quote Originally Posted by Pandito bandito View Post
    I've had my battery near dead and it is doing the same. Also the TPMS and ESP lights come on about 10 mins into a drive
    Sent from my SM-N910T using Tapatalk
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Jul 19 2016
    Missouri
    Yeah when I replaced the battery I got esp off an said all sorts of bulbs were out. Esp works fine but I am still getting all the bulb warnings even though the bulbs are in fact working.
    Oct 01 2016
    León / Spain
    Does your screen never turn on? Is it always black?
    Oct 01 2016
    León / Spain
    If you disconnect battery, when you connect battery, ESP light remain on until you get around some meters.
    When ESP light remain ON, usually it is due to faulty battery.
    When you change the battery, you have to code module of battery.
    Jul 19 2016
    Missouri
    When I first replaced the battery I had to hold the power on/off button (next to screen by glove box release) a couple times to get mmi working but it came on. After the first couple times driving it though the mmi stopped working completely even if you tried to power it on/off with the button.
    Jul 19 2016
    Missouri
    How do you code the module? I have a schwaben vagcom scanner
    Oct 01 2016
    León / Spain
    Ok, the screen is always black (OFF). And, do you have sound (radio, music ...) ? If you have vagcom, you can diagnose the problem. If you have sound, the problem can be the screen. If you dont have sound, the problem can be Gateway. If you dont give a code your new battery, it work but it is advisable code so that sistem knows that it has a new battety and what battery. Battery recommendable is 110 Ah.
    Oct 01 2016
    León / Spain
    Coding battery
    [Select]
    [61 - Battery Regulation]
    [Coding - 07]
    Use the pull down menu to select the battery (slave) listed as 1.
    [Battery Coding]
    Enter the new Battery Part Number (10 or 11 digits).
    Enter the new Battery Serial Number (10 digits).
    Select the new Battery Vendor.
    [OK]
    [Do it!]
    [Close Controller, Go Back - 06]
    Jul 19 2016
    Missouri
    Have still not tried to code battery. But dug through the car the other day checked all fuses in driver an passenger dash and trunk fuse box. No blown fuses. After pulling fuses started the car and MMI worked fine played radio switched to disc changer and played multiple discs. Worked the whole time I was pulling codes with my scanner. But when I tried to clear codes MMI shut back off. Rechecked fuses didn't blow anything. Here's the codes I got
    02072: control module for energy management (J644)sporadic -004-no signal/communication
    00446: function limitation due to under voltage -002 sporadic
    02445: disk drive initialization error
    02444: disk drive load eject malfunction
    Please let me know if anyone has any ideas or suggestions.
    Registered Member One Ring Acyl24's Avatar
    Nov 17 2016
    Montreal
