I know. It is designed to retain the o-ring. But it is plastic and can possibly dry, get brittle, and have parts break off and get chomped by the intake valves. Or even worse they get chomped up fully, o-ring is of sub-par fitment (can just about guarantee they are...sitting in your fuel rail and intake manifold right now) that falls into the valve area.
Already posted a recommendation, if you caught onto it. And not sure if you ever took the stock one off or not, because they get brittle after time and do exactly what I just posted (they def can be taken off, but you need to be gentle or they can possibly crack in the process). But...the stock stops are small and really cause no real harm. But if the o-ring by some anomaly of life were to drop in there, kind of hard to chomp and chew up something made of rubber before it enters the combustion chamber (hope it melts fast and does not compromise your piston rings before trying to make it's way out the exhaust...passing some more valves...into your turbo). Doubt the design for fitment will even work on your new injectors (really don't know).
This is one of those "How the f*ck did that happen situations?!?!", but is the extreme end of the spectrum...maybe. Doubtful that will ever happen. But having an o-ring drop into the head while trying to pull the injectors out is one reason why they exist. Happens often, and why people usually suggest taking off IM at same time (or just unbolt it off head, move to the side, cover intake ports, and now problem solved. you can even do something like just slide the IM back far enough after unbolting, or just loosen bolts and two nuts, and slide index cards over the ports to prevent it from happening. shop vac it back out by slightly sliding index card off runner to allow velocity for shop vac to take in the o-ring. now...problem averted. many ways to go about it).
As for the surging, you should have stated that. On a turbocharged vehicle and you stating that you run 630cc injectors, most would think of the turbo surging (probably everybody. ha). You have more of what one may refer to as RPM fluctuation at idle, erratic RPM at idle that stays between such and such RPM...or surge
. Sorry, too easy. Meant no disrespect or ill intent. Just busting chops !
So next question, what tune are you running? And did you try a throttle body adaption via Ross Tech or similar programming to do a full reset?
