Results 1 to 20 of 20
    Veteran Member Three Rings 0396's Avatar
    Feb 10 2005
    L A
    S/4 Engine Mounts
    Quick question for the brain trust.
    What are the symptoms of a bad motor mount and or at what mileage should they be replaced?
    Thanks in advance for your reply.
    0396
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    More vibrations than usual
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    unusual vibrations
    excessive drivetrain "slop"
    code for a broken engine mount(yes ,they have circuits inside them)
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    If you get under the car you can inspect them. If there's a bad smelling reddish/purple oil leaking it's likely from the mount.
    Jul 15 2015
    Rochester NY
    The whole engine can lift under torque and then clunk back down when you throttle off.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    you can replace them anytime with 034.... it wont hurt your feelings, but could possibly affect your
    PAST
    2004 Audi (B6) S4 4.2L
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167
    Current
    2015 Audi (B8.5) A4 2.0T P+ Sline ECS-Luft-Technik Intake System/Air Scoop v2/Silicone Intake Tract Set with turbo muffler delete, GFB DV+ VTA Performance Blow-Off Valve, JHM FMIC/ECU and TCU (Automatic 8 Tip Quattro) Stage 2 tunes. Cosmetic RS4 Honeycomb Mesh Front Grille and Fog Light Vent Grilles
    Veteran Member Three Rings Velox's Avatar
    Mar 30 2016
    S4
    Oranjestd
    Just had mine fail, most noticeable was heavy clunks on acceleration, and more vibrations in general
    Feb 04 2016
    London
    One of mine separated into 3 pieces. No lights or codes thrown. Didn't even know until I went to replace it with a 034 mount!
    Feb 10 2005
    L A
    Well with 109k, and since I also have a new starter, I simply replace both of them when I had the starter replaced as a preventive measures.
    0396
    Established Member Two Rings dmanisgnarly's Avatar
    Nov 05 2014
    Supermotos & Sportbikes
    The East Coast, NC
    034 Billet Motorsport mounts..the only real solution to the V8 torque!
    2005 S4//K&N/Pod filter/Carbon MAF extension/APR Carbon NACA ram-air duct/JHM intake-mani spacers/Gutted piggies/Custom Catback/034 Motorsport billet engine mounts/19” Peelers/034 Snub/Neuspeed lowering springs/JHM stage 4 Kevlar clutch/Rallyarmor mudflaps/Rocketbunny V2 front diffuser/canards/HIDs/DRLs/LEDs/trailer hitch
    02' A4 1.8T Quattro
    Feb 10 2005
    L A
    Guys, thanks for the suggestion. Since I was not aware of 034, I simply order a complete set of factory mounts. - live a learn.
    0396
    Nov 30 2014
    Dallas, TX
    Quote Originally Posted by 0396 View Post
    Factory mounts with the circuits cost a lotta money and wear out pretty quick, any chance you can return them? FCP euro has mounts without the internal circuit for $90 each but honestly 034 is the best!
    Feb 10 2005
    L A
    Quote Originally Posted by gautam View Post
    Well, they have been installed already...paid a pretty penny for the install of a new starter ( preventive measures) and new plugs at the same time...its all good as my S/4 is much better now.
    0396
    Nov 30 2014
    Dallas, TX
    Glad it worked out!
    Nov 05 2014
    The East Coast, NC
    I wouldn't worry unless you're dumping the clutch after 5 grand repeatedly... Will be doing my rear diff mount next!(search the poly fill diff DIY on here) Have you checked out your snub? Chances are its beat if the motor mounts were toast. Bought my B6 with 112K and pretty much every drivetrain mount was trashed. After replacing the motor mounts with 034 billet, snub with 034 poly, and a jhm shifter bushing upgrade I could immediately tell a difference in firmness on clutch shifts and a smoother transfer of power. Coupled with a stage 4 JHM Kevlar clutch, there arent much extra vibrations..the V8 does a good job soaking them up..My B6 A4 on the other hand..I don't know if i would go as rigid with the mounts... You can feel every little bump with the 4 banger.
    02' A4 1.8T Quattro
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    I got my 034 mounts waiting for when i redo my axles.
    Feb 10 2005
    L A
    Snub, I had that replaced with a factory one two years ago when it was in for an alingment check up and related front control arm bushing...it was one of those, might as well be proactive vs reactive strategies.
    0396
    Nov 03 2011
    All Over!
    As far as motor mounts go, you can't beat these Motorsport babies from VibraTechnics. They've been around since the mid-1980's, and are very well proven. I've not seen anyone break these, and they're compliant enough to use on a road car, yet tough enough to withstand daily hard launches!
    I used them in my B5 V8 swap.
    I used VibraTechnics mounts in my 1991 VW Golf 1.8 16V turbo, which made 347hp / 302 lb-ft. I'm using the same in my B6 4.2 V8 turbo.
    1986 Type 85 Audi 90 quattro
    Jul 05 2016
    Ontario, Canada
    timing chains on the front? Belt driven A/C?.. doesn't smell like BHF
    Nov 03 2011
    All Over!
    Quote Originally Posted by roboto_1337 View Post
    Haha, yeah. The chain-driven, 079-series V8 motors are garbage. Great when they're working, crap when the motor needs to be pulled.
    I stick with the ultra-reliable, belt-driven 077-series V8 motors, even in my B6.
    But back on topic, these mounts are superb.
    You meant timing belts on the front, though.
