I installed the Sub/Amp about 1 week ago without much problem or issue. The JL12 thin line sub and JL500 mono amp is an amazingly capable sub and sounds perfect when functioning properly.
The unecessary Bose Active Noise Cancelling renders this sub mostly useless. If I tune the sub gain to a point where I like then it reverberates when idling the engine or low RPM situations. If I turn the sub down to avoid this, then it sounds mostly stock. Only when I dial the bass up in the MMI can I tell it is not the factory sub. Even then, it is not sound like a sub that I would have gone through the trouble for.
I don't want to cut Wires to the microphones in the liner of the ceiling and don't have a VAG to somehow disable.
Is there any other solution that has worked? If not, I am yanking the system and simply going to learn to live with the BOSE factory system.
