Results 1 to 6 of 6
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    97 vs 95 tire rating
    So I just came back from Discount Tire and was told that they couldn't mount my 225/45/R18 95H Blizzaks because they aren't allowed to per the load rating being not 97(OEM load rating) or 95XL. They mounted the same tires last year on my '06 Avant I had, which calls for the same requirements. Would it be a risk to just go somewhere else and get them mounted anyways? I'm not trying to cheap out or anything, but if it's not a safety issue, then I don't want to go through the process of selling these and looking for another set. The difference per tire load is 1521lbs vs 1609lbs. My wife usually drives the car and doesn't carry anything in the cargo hold except for a few bags of groceries here and there.
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    im running 245/35/20 dws-06 95y xl rated tires on my c6.5.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Mar 28 2016
    Quote Originally Posted by ichi d View Post
    OP's question is about running 95, not 95XL.
    May 17 2009
    Idaho
    Yeah XL 95's are fine. As ichi said, I'm referring to non-XL rated 95's. I think I'll be fine. We had them on last year. I think they rate tires with cargo and 5 adult passengers inside the vehicle, something we'll never have.
    Current:
    2002 1.8t A4 Sedan
    Jul 17 2011
    Sin City, USA
    The tires are not rated for the weight of the car. You are correct that the car is weighed with all fluids (full tank of gas), 5 average sized adults and some weight in the truck to simulate luggage.
    Discount wont mount them because it exposes them to liability if they knowingly mount under rated tires and something goes wrong.
    You may not have issues because you won't ever meet the weight, but you will have to find a tire shop that doesn't care about liability.
    '09 C6.5 A6
    May 17 2009
    Idaho
    Oh I totally get that and if in there position, I'd say the same thing. It's just that I was taken back a bit when last year, the same shop mounted the tires onto the wheels for the same vehicle no problem(obviously someone wasn't paying attention then).
    Current:
    2002 1.8t A4 Sedan
