Hi everyone,
I have a 2008 A4 2.0T. I was planning on changing the thermostat this weekend, but after reading some other posts, I am not sure if my problem is with the thermostat or temp sensor? Since changing the thermostat is pretty involved, I figured I'd see what you thought. My symptoms are...
Gauge does not go up halfway (to 12 oclock). It usually hovers around a quarter. If it sits and idles and may go up, but once I start driving it drops back down.
Does have Check Engine Light, with "Cooling system performance" code.
I do have heat, the heat works fine.
I would assume if the thermostat was bad, I would not have heat?
Is there a way to test the temp sensor?
Thanks for any advice!
