Results 1 to 8 of 8
    Senior Member Two Rings TurboNate's Avatar
    May 16 2015
    El Cajon/CA/San Diego
    flutter around 3000RPM
    So recently my car has been fluttering at around 3000 rpm and I'm getting a lose of power when it does so. I've been told it's a boost leak and that I'll need to get a GFB DV+ and it should fix he issue (since I'm tuned). I've attached a video. Just want to get a second opinion. Thanks in advance.
    2009 A4 Premium+ Quattro
    APR Stage 2 | CTS Turbo High Flow Cat | Custom Intake System | AG 19x9.5 m580 w/ 10MM Spacers In Rear | RS Mesh Grill | 5% / 20% tint
    AKA: NathanMansoor
    Oct 11 2016
    Massachusets
    Get a dv+, it's definitely worth it.
    Sent from my SM-G920V using Audizine mobile app
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    DV+ is a nice mod, but the updated DV without the rubber is pretty solid on the B8s.
    Why not do a smoke test to figure out where the leak is coming from instead of guessing?
    May 16 2015
    Quote Originally Posted by kdaffy View Post
    I was thinking about getting that done before, but Idk where to do it. Does any auto shop have a smoker?
    AKA: NathanMansoor
    Apr 17 2014
    MA
    ^they should...i would call around a few shops and ask, otherwise you may end up throwing parts at the car for no reason.
    Veteran Member Four Rings Chanman94's Avatar
    Jun 09 2014
    Calgary, AB, Canada
    My car has done the same before, my leak was in the PCV, so that could be a place to check.
    - Richard
    2017 Audi A4 Allroad - Mythos Black - 034 Dynamic+ Springs - Volk Racing TE37 Ultras
    2021 Lexus NX300 - Ultra White - BBS Evo X Wheels
    2017 Honda Civic Touring - Lunar Silver - Sold
    2018 Volkswagen Golf R - Oryx White Pearl - Sold
    RIP - 2010 Audi A4 - Monza Silver
    - Apparently not resting in peace anymore.
    May 16 2015
    Quote Originally Posted by Chanman94 View Post
    Hmm I could check that out. I'll pull it out and check the flapper
    AKA: NathanMansoor
    Oct 30 2006
    B8 A4 Avant 6spd
    Check for oil leaks from the front main cover / front main seal area as well. (Cause lean condition/ affect pcv) Also, on cars that have gotten oil consumption done that have the updated breather, the updated breather goes bad. 2012/2013 cars that share that same breather get the 17F9 Recall to change the diaphragm inside along with the spring. It is significantly better.
    -18 718 GTS
