Originally Posted by
diagnosticator
While the '02 F ECU has a different clock speed than the later ECUs I don't believe that has any particular effect on compatibility. The instrument cluster does not know or care what the ECU clock speed is. There is nothing regarding the ECU internal clock speed that has any external compatibility dependency. The ECU communicates with the IC via CAN buss and the CAN runs at 500 baud between the ECU and the IC, that is the same CAN speed that all B6 power train CAN busses run.
I have never seen a Japanese IC, they are all Bosch. There is no '02 only IC in the parts lists, only different part numbers are listed for different PR numbers.
The one I looked at for the years in question all had the same country of origin and appear to be made at the same plant. Perhaps the actual change was the supplier of the display (the little LCD)? Not sure.
I also took a look at Car-Part.com. They don't seem to show much interchange between years. However when you take the part numbers from the clusters and google them, it shows that many of them interchange.
The only other possibility would be different commands to the ECU that are not supported between years. I don't think this is a problem. I am curious to see if the options on the readout varied between years. My 2003 does not have mile traveled on short trips. I get short trip fuel economy and how long I have been driving, but not how far I went. I know that the dealer replaced the cluster... Not clue on the part number.
PN pulled from a 2002 cluster: 8E0920950H
Jim Ellis Auto shows that PN fitting 2002-2005
8E0920950P is for the 2004-2005, Wolf Auto shows it fitting from 2002-2005.
It would be interesting to find out what changed on the newer versions.
http://www.wolfautoparts.com/instrum...0p-132480.html
