Results 1 to 2 of 2
    Oct 04 2016
    Bartlesville, OK
    Problems with driver's seat and keyless entry, possibly CCM related
    I've got a 2004 S4 and the driver's seat base and back rest won't move fore/aft (but the pneumatic lumbar support still works). This has been a persistent issue since I got the car about a month ago. I have VCDS and have followed the remote learning procedure on both keys and it doesn't recognize either of them. I also have the radio out at the moment, which is why the steering wheel is throwing an error. The code that is concerning me is 01336 and the subsequent ones dealing with the door modules. I've pulled the CCM and it doesn't appear to be wet or corroded, I plan on checking the wiring to the CCM this weekend though, to make sure there isn't a short.
    Any help is greatly appreciated.
    VCDS Version: Release 15.7.1 (x64) Running on Windows 8 x64
    Data version: 20150904
    www.Ross-Tech.com
    Thursday,03,November,2016,18:57:06:05031
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: WAUPL68E04A164189 Mileage: 210160km-130587miles
    Address 01: Engine Labels: 079-910-560-BBK.lbl
    Part No SW: 8E0 910 560 A HW: 8E0 907 560
    Component: 4.2L V8/5V G 0020
    Coding: 0007711
    Shop #: WSC 24101 444 52347
    VCID: 234277A3E1C65F2660-5072
    No fault code found.
    Readiness: 0110 1101
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 Q
    Component: ABS/ESP allrad 3033
    Coding: 04595
    Shop #: WSC 06435
    VCID: 3664BEF71254DA8EB7-5072
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1424
    Coding: 00000
    Shop #: WSC 06335
    VCID: 63C237A3F1461F2620-5000
    1 Fault Found:
    01336 - Company Data Bus for Comfort System
    80-00 - Single-Wire Operation
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul USA 0517
    Coding: 01013
    Shop #: WSC 63351
    VCID: 3566B9FB0F52D196BE-4A3A
    1 Fault Found:
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 K
    Component: Airbag 8.4EP 1001
    Coding: 0010607
    Shop #: WSC 63351 000 00000
    VCID: 3F8ADBD36D6E1BC664-5000
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 04041
    Shop #: WSC 63351
    VCID: 3E74A6D73A6412CE6F-4A9C
    4 Faults Found:
    01304 - Radio
    49-00 - No Communications
    01303 - Telephone Transceiver (R36)
    49-10 - No Communications - Intermittent
    01301 - Control Module for Voice Recognition (J507)
    01330 - Central Control Module for Central Convenience (J393)
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 981 G
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 01229
    Shop #: WSC 00222
    VCID: 316E8DEBFB3AFDB6E2-5072
    WAUPL68E04A164189 AUZ6Z0C0389135
    2 Faults Found:
    01304 - Radio
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1411
    Coding: 11788
    Shop #: WSC 63351
    VCID: 72EC42E73EBC86AE5B-4A9C
    Subsystem 1 - Part No: 8E1959801
    Component: Tőrsteuer.FS BRM 0004
    Subsystem 2 - Part No: 8E1959802E
    Component: Tőrsteuer.BF BRM 0004
    Subsystem 3 - Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0004
    Subsystem 4 - Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0004
    5 Faults Found:
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    01333 - Door Control Module; Rear Left (J388)
    01334 - Door Control Module; Rear Right (J389)
    Address 75: Telematics Labels: 8E0-035-616.lbl
    Part No SW: 8E0 035 616 A HW: 8E0 035 616 A
    Component: Telematik USA1
    Coding: 0005303
    Shop #: WSC 24103 444 58002
    VCID: 234277A3E1C65F2660-5000
    3 Faults Found:
    01656 - Crash Signal
    004 - No Signal/Communication - Intermittent
    01304 - Radio
    01531 - Emergency Battery
    002 - Lower Limit Exceeded - MIL ON
    End-------------------------(Elapsed Time: 06:05)--------------------------
    Sep 11 2024
    Toronto, Canada
    Did you ever get this resolved? I have a the same issues with my B6 S4 Cab, driver seat moves front and back, however the height and backrest do not move. Headrest and lumbar supports operate fine.
