Results 1 to 10 of 10
    Nov 02 2016
    NB, Canada
    2006 A4 Avant Sharkfin antenna
    As title says, I am looking for a Skarkfin roof aerial for an 06 A4 Avant. Part number is 8E9035503PGRU. Used is fine, really only need the plastic piece off the top but will buy the whole thing if needed. Car is Black but would consider any color.
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    Jan 24 2008
    Pennsylvania
    I have one that is Ibis, its wrapped up and tucked away in a box somewhere. I'll see if I can locate it in the next day or two and see if the P/N matches what you're looking for.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Nov 02 2016
    NB, Canada
    Quote Originally Posted by Turbavanttro View Post
    That would be great, thanks.
    Senior Member Three Rings wjg22's Avatar
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    OP, if turbavanttro isn't able to find his, I picked one up from eBay for a good price (full antenna). I sprayed it and just installed it today.
    Nov 02 2016
    NB, Canada
    What did you use for paint? Was it a hard install to get the headliner out?
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    I had some color matched paint and clear coat left over from when I got s4 door blades, so I just used that. I think I got it from automotivetouchup.com.
    Install was easy. If you're not swapping out the whole unit you don't even need to drop the headliner. Remove the rear light fixture and unscrew the bolt holding the shark fin on, then lift it up off of the roof. That should give you enough room to screw the new cover.
    Nov 02 2016
    NB, Canada
    Correction. I took my antenna off today and I actually need part number 8E9035503KGRU...so a K instead of a P.
    Veteran Member Three Rings JB5's Avatar
    Jul 19 2010
    96 B5 A4- Sold, 06 corollaS (wife's), 97 Ford Ranger, B6 A4 (Daily Driver)
    Snellville, GA
    Not sure if it's the same but I'm selling an antenna with it's amp for $80.00. came off a sedan so I'm not so sure if it fits the Avant models. here's the link in Panjo:
    https://www.panjo.com/buy/fs-roof-an...r-80-00-236016
    Nov 02 2016
    NB, Canada
    Does your have a part number on the bottom of the antenna? I do not think it will fit but if you could check the number that would be awesome.
