Results 1 to 9 of 9
    Established Member Two Rings 029kid's Avatar
    Nov 13 2006
    Audi A4 2017 Avant 2.0 TFSI
    Oslo, Norway
    Exclamation Need help understanding fault codes
    The engine light in my A4 B8 Avant 2011 started to appear yesterday, now it suddenly disappeared.
    I run a scan, and found some errors.
    What do they mean ?
    Thursday,03,November,2016,20:24:24:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 8T0
    Scan: 01 03 05 08 09 10 15 16 17 18 19 20 42 46 52 53 55 56 5F 62
    6C 6D 72
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    18-Aux. Heat -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    20-High Beam Assist. -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (DET-CDNC) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 AE HW: 8K2 907 115 L
    Component: 2.0l R4/4V TF H09 0002
    Revision: ECH09---
    Coding: 010C000C185F0160
    Shop #: WSC 56847 000 1048576
    ASAM Dataset: EV_ECM20TFS0118K2907115AE 001003
    ROD: EV_ECM20TFS0118K2907115AE.rod
    VCID: 72E1C411A5B4009
    1 Fault Found:
    2970 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 00 [104] - Implausible Signal
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 16
    Mileage: 107502 km
    Date: 2016.10.14
    Time: 08:29:00
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
    Component: ESP8 quattro H04 0060
    Revision: -------- Serial number: --------------
    Coding: 070D0C
    Shop #: WSC 06334 000 00000
    VCID: 820114D11D14B09
    No fault code found.
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 CQ HW: 8K0 907 064 CQ
    Component: BCM2 2.0 H05 0435
    Revision: 00002001
    Coding: 072200
    Shop #: WSC 06335 000 00000
    VCID: 81031BDD1812AB1
    Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AH HW: 8T1 820 043 AH
    Component: KLIMA 1 ZONE H08 0180
    Revision: A1000000 Serial number: 01250420110323
    Coding: 64380000
    VCID: 77F7F505C6D6651
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H30 0392
    Revision: 10030001 Serial number: 00000000876302
    Coding: 2600D0914074AF211701000300001D0D4F9C07080601012100 0000
    Shop #: WSC 58954 123 10485
    VCID: 3C7D2A29BF70869
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 190411 H07 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Subsystem 4 - Part No SW: 8K0 907 410 HW: 8K0 907 410
    Component: EHL205.06.02K H02 0010
    2 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 103
    Mileage: 102424 km
    Time Indication: 0
    Date: 2016.06.20
    Time: 13:02:00
    03207 - Charisma Switch Module
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 103
    Mileage: 102424 km
    Time Indication: 0
    Date: 2016.06.20
    Time: 13:02:00
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 AA HW: 8P0 919 475 N
    Component: PARKHILFE 8K H01 0080
    Revision: 11001001 Serial number: 12501111601810
    Coding: 300203
    VCID: 78F5F639CBC86A9
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 L HW: 8K0 959 655 L
    Component: AirbagVW-AU10 H44 0610
    Serial number: 003JMD0B0J45
    Coding: 30513435363030303030554A304C384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 468948C1F9BCCC9
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME5E622C6DX
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME5F14674CS
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME69095044E
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME080109747
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME5B013C4A2
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME44074164U
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
    Component: Lenks.Modul H07 0156
    Revision: 00000000 Serial number: 20110421000436
    Coding: 000017
    VCID: 499343FDE0A2231
    Component: E221 - MFL H02 0010
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 930 M HW: 8K0 920 930 M
    Component: KOMBIINSTR. H28 0258
    Revision: 00000000 Serial number: EJ823NF4C
    Coding: 0305110003000008000000
    Shop #: WSC 56847 123 10485
    VCID: 377735058656A51
    Address 18: Aux. Heat (J364) Labels: None
    Part No SW: 4H0 265 105 HW: 4H0 265 105
    Component: Standheizung H22 0240
    Revision: 56005006 Serial number: 20110323202110
    Coding: 4D2000
    VCID: DFC73DA5CE263D1
    1 Fault Found:
    01406 - No Flame
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 86
    Mileage: 107004 km
    Time Indication: 0
    Date: 2016.10.09
    Time: 14:06:07
    Freeze Frame:
    Temperature: 2.0°C
    Temperature: -6.0°C
    Voltage: 10.80 V
    Start
    Error Code: 70
    Temperature: 1.0°C
    RPM: 0 /min
    Yes
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 AE HW: 8T0 907 468 L
    Component: GW-BEM 5CAN-M H10 0117
    Revision: FC100058 Serial number: 5800F11408805F
    Coding: 00CF07
    VCID: 840D12C90700BE9
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0140
    Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
    Component: J532_DCDCStab H17 0042
    2 Faults Found:
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 7
    Fault Frequency: 108
    Reset counter: 109
    Mileage: 102431 km
    Time Indication: 0
    Date: 2016.06.20
    Time: 14:35:00
    03041 - Energy Management Active
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 155
    Reset counter: 108
    Mileage: 102431 km
    Time Indication: 0
    Date: 2016.06.20
    Time: 18:35:00
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 12.40 V
    Count: 17
    Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
    Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
    Component: FLA H04 0004
    Revision: AA001002
    Coding: 02019164747464545425363E
    VCID: 336F0115922E491
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
    Component: TSG FA H12 0357
    Revision: Serial number: 0000006046106
    Coding: 011C12204000410001
    VCID: 4A917CF1E5A4289
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0148797700
    Coding: 01000E2020B974558330023680000000
    Subsystem 1 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
    Component: J245 PS136 H07 0041
    Subsystem 2 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
    Component: J394 PS240 H08 0043
    1 Fault Found:
    03233 - Controls for Garage Door Opener (E284)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 103
    Mileage: 102424 km
    Time Indication: 0
    Date: 2016.06.20
    Time: 13:02:43
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
    Component: TSG BF H12 0357
    Revision: Serial number: 0000006023814
    Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 10000000785659
    Shop #: WSC 00000 000 00000
    VCID: 346D020997204E9
    Address 55: Xenon Range Labels: 8K0-907-357.clb
    Part No: 8K5 907 357 B
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000004
    VCID: 3973333D7042B31
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 056 D HW: 4G0 035 056
    Component: Radio U STD H52 0094
    Revision: AB001007 Serial number: 469D+0B7720493
    Coding: 010003020100000001
    VCID: 2241F4513DD4D09
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 8T1 035 670 J HW: 8T1 035 670 E
    Component: H-BNT-EU H51 0174
    Revision: -------- Serial number: 491D-0B7553084
    Coding: 010100010006E3EF05000F1E000000030000
    Shop #: WSC 58954 000 1048576
    Subsystem 1 - Part No: 8R0 060 884 N
    Component: EUR 2011 1205
    Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
    Component: DU7 High H43 0098
    Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
    Component: E0380 Bedient H08 0100
    Subsystem 4 - Part No: 8R0 060 961 A
    Component: CD-Database 2712
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
    Component: TSG HL H11 0357
    Revision: Serial number: 0000006076551
    Coding: 010C12204000210001
    VCID: 458B4FCDCCBAC71
    Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
    Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
    Component: J772__Rearview 0040
    Revision: --H05--- Serial number: 525PA8-J1191SV
    Coding: 1020007
    VCID: 387536394B48AA9
    Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
    Part No SW: 8K9 827 851 A HW: 8K9 827 851 A
    Component: J605 Master H52 0330
    Revision: -------- Serial number: 8K9827851A
    Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A
    Component: J756 Slave H52 0330
    Address 72: Door, Rear Right
    Cannot be reached
    End ---------------------------------------------------------------------
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    I'm sure Infiltrator will be more than happy to give you some patient and pleasant advice.
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    most concerning is the first one, P2015. You likely need a new intake manifold. These parts are known to be faulty.
    Most of the rest were one time faults...I would clear and see if they come back. Likely nothing, but you never know.
    Nov 13 2006
    Oslo, Norway
    Sounds expensive ?
    I found this:
    http://www.audizine.com/forum/showth...Signal-Problem
    His solution was this:
    Würth Fuel Injector Cleaner Additive
    Is that just BS ?
    Apr 17 2014
    MA
    worth a try, but you are better off getting a complete carbon cleaning (albeit for much more than the can)...the cans can only do so much, and being that the engines are DI, you will be back to where you are right now. Issue is, if one of the flaps is broken or malfunctioning, then the can or carbon cleaning wont help you at all, and you will need to replace the manifold.
    You have a few options.
    1) try the can and hope for the best
    2) get a full carbon cleaning
    3) replace the manifold
    Since you are at 100k+ km, i would recommend #2 or #3. Do you know what your engine code is? CCTA and CBFA engines have an extended warranty on the manifold...others possibly as well.
    Apr 17 2014
    MA
    Quote Originally Posted by ToddBrunswick View Post
    haha...ill help him out since he hasnt chimed in yet.
    clicky AND SEARCH!
    Nov 13 2006
    Oslo, Norway
    Thanks you for answering.
    1.
    Ok, Ill try the can.. Im planning to sell the car and get B9 in 3 months.
    I was sure I had a CAEB engine (?) but I just checked ERWIN and it says: Engine code CDNC ?
    Does that also has an extended warranty ?
    2.
    As the engine light turned on yesterday, there is no sign of that being logged in the scan. Why is that ? All other fault codes are logged with timestamps.
    Apr 17 2014
    MA
    yeah, if you are getting a b9 in 3 months, dont spend the money...do the can, see what happens, and worst case, move your timeline forward (if possible) towards the b9.
    Good Luck!
    Nov 13 2006
    Oslo, Norway
    I just had my intake manifold replaced, 1376 USD...
    Now the engine lights are back on, saying:
    Revision: ECH09---
    3 Faults Found:
    7843 - Intake Air Temp. Sensor (G42)
    P0113 00 [237] - Signal too High
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 110811 km
    Date: 2016.12.21
    Time: 18:54:53
    4206 - Intake Air Temp. Sensor (G42)
    P0112 00 [237] - Signal too Low
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 110811 km
    Date: 2016.12.21
    Time: 18:54:53
    4186 - Intake Air Temp. Sensor (G42)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 110811 km
    Date: 2016.12.21
    Time: 18:54:53
    Readiness: 0000 0100
    Is this related to the swap of the intake manifold? If so, can I have them fix this for free or is this a repercussion for the faulty intake manifold and Ill have to pay them even more bucks ?
    If not, is the IAT integrated in the MAF so I can clean or swap the MAF to fix this ?
