Results 1 to 8 of 8
    Veteran Member Three Rings piotrowr's Avatar
    Jul 18 2008
    Scottsdale
    alternator pulley bearing decoupler
    A local shop informed me that this item is what's causing a repetitive clunky noise when the car is put into drive or reverse. They said it would eventually need to be replaced but is it potentially covered on our extended transmission/drive train warranty? I have 56K miles.
    2010 A4 Avant Prestige - 19" Sport Package, Quartz Gray Metallic
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    What does the ADP have to do with the drive train? If yours is on the way out, I would think you would want to replace it before it fails.
    2011 A4 Avant
    Jul 18 2008
    Scottsdale
    My bad, not related to drive-train but did read somewhere about at TSB for it. Any info on that?
    Nov 17 2010
    Not that I've seen.Perhaps other may know. In fact, this is the first post I've seen about the ADP.
    2011 A4 Avant
    Jul 18 2008
    Scottsdale
    The shop wants $355 to replace. I find the part on Rockauto ranging from $80-115. Sounds like they are charging 2 hours labor.
    Nov 17 2010
    Quote Originally Posted by piotrowr View Post
    Or they are charging more for the part, which is quite likely. The alternator may have to come out since space is a bit tight to get the two tools needed to release the pulley...one socket to hold the shaft and a second to release the pulley. Probably more than 1 but less than 2 hours.
    2011 A4 Avant
    Jul 18 2008
    Scottsdale
    Another shop just said 1 hour labor $100 plus about $90 for the part. Big difference. I had it there before and probably trust them better anyway.
    Nov 17 2010
    Ya, that sounds reasonable. It's not a big job.
    2011 A4 Avant
