Results 1 to 16 of 16
    Established Member Two Rings MaudiS4's Avatar
    Jan 03 2009
    1999.5 AUDI A4 2005.5 B7 S4
    Silver Spring , Maryland
    SOLD !!!!Big Brake Kit- Porsche Cayenne 18Z calipers and bolts
    Big brakes for B6/B7 S4 with mounting bolts.
    Porsche Cayenne Calipers loaded with new brake pads and new wear sensor
    US$ 750.00 + shipping.
    Location MD - 20905
    Text / Call 240-645-7188 Mau.
    FullSizeRender (3).jpgFullSizeRender (4).jpgFullSizeRender (5).jpgFullSizeRender (6).jpg
    Jan 03 2009
    Bump
    Veteran Member Three Rings TagEldinAhmed's Avatar
    Dec 06 2015
    Los Angeles, CA
    Are these 17z or 18z's?
    Jan 03 2009
    They are 18z"s.
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    I'm a boob,. Do I need a different mounting bracket? Also what rotors could I run?
    Sent from my Nexus 7 using Audizine mobile app
    Jan 03 2009
    No bracket to install it. Just the 4 bolts included in the kit and some trim to the dust shield.
    We can use the stock brake rotors.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Quote Originally Posted by AllroadMass View Post
    You'll also need RS4 brake lines. These are best fitted with 2002 ML55AMG rotors (you'll need to mill the centre bore by 1mm). Ask me how I know; I have an actual complete kit. You can open the centre hub bore with a flapper wheel and drill.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Jan 03 2009
    BUMP
    Veteran Member Four Rings brandonpham's Avatar
    Dec 07 2014
    Belleville, NJ
    I thought stock rotors sit very off center from the caliper?
    Jan 03 2009
    No, they are just right !
    Check the link...
    https://goo.gl/images/P9WGhF
    Active Member Two Rings chris4521's Avatar
    Dec 14 2015
    Toronto, ON
    Quote Originally Posted by brandonpham View Post
    You're right they do. Stock 18z will not fit the stock rotor.
    If you machine the morning tabs on the 18z caliper they will.
    If you use ml55 rotors you are fine.
    Nice calipers, GLWS
    08 S4, 2.5" Catless downpipes, 2.5" Fast Intentions non-res, JHM Tune
    13 S4, ECS LT Intake
    Jan 03 2009
    Bump
    Jan 03 2009
    Bump!
    Jan 03 2009
    Bump
    Jan 03 2009
    Bump !
    Established Member Two Rings RAUDIRS6's Avatar
    Dec 02 2013
    18 RS7P, 14 Q7 TDI
    Lusby, MD
    Got 'em. Great guy to work with. Met me half way between. Thank you.
    Sent from my SM-N920V using Audizine mobile app
    2018 RS7 Performance (Nardo)(DS1 Mod Stage 2, JHM TCU, ECS Intake/Inlets, CWA-100, ARM DP w/ HF Cats, ECS 2.75" Valved Exhaust, 40T E-Sensor w/Bypass & Lines, 034M HPFP, Forge BOVs, JHM T&D Inserts, 034M Tunnel Brace)
    2014 Q7 TDI (RSNav)
    2004 S4 Avant 6MT
    2003 RS6 (6MT Conversion Project)
    2002 Passat Wagon
    1998 Passat Sedan ($1250 Budget Build Project)
    2000 New Beetle
