I did a full timing service with the exception of the electric adjusters...year later, passenger side cam adjuster solenoid goes bad...I've slowly been working on it from the top, it is now at a friend's shop because of a stripped valve cover bolt. We are going to tear into this thing next week and finally swap the cam adjuster solenoid out. I'm afraid of the new solenoid going bad due to something else causing it, I guess what I'm wondering is did something cause the previous one to go bad? Faulty wiring? Fuse? Is there something I should be checking before I fire the car up? I would be quite pissed after all this work if the new solenoid blew out because of something else!
