Results 1 to 7 of 7
    Jan 12 2011
    2016 Q5, 2018 S90
    Winter wheels fitting
    I picked up some winter wheels with tires from a forum member. They were on his b8.5 s4. I believe they're 18x8 et 47. Will these fit adequately on my 2013 s5? Will I need to get spacers? I'm not particular about the wheels being flush during the winter. I just want to get proper functionality out of them.
    Sep 28 2010
    NW NC / DE
    You're going to want to run 25mm spacers just to get back to near OEM S5 fit.
    Jan 12 2011
    2016 Q5, 2018 S90
    Is it safe to do this? I don't mind using spacers, as long as the brakes are cleared and nothing will cause stress on the suspension. It's only for a few months of the year as it is
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by DontHait View Post
    Yes, completely safe. Once mounted up properly, they're simply an extension of the hub. Brakes will be cleared too.
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    Just make sure you are using the proper length bolts to account for the extra distance from the hub.
    Sent from my XT1575 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Jan 12 2011
    2016 Q5, 2018 S90
    Quote Originally Posted by Sweep View Post
    I believe the h&r DRA come with bolts. Correct me if I am wrong please
    Veteran Member Four Rings mtndog's Avatar
    Jan 22 2009
    992 GTS, F90 M5c, G05 X5 M60
    pnw
    You are correct. You will use your stock bolts for installing the wheel. i have a set I will be putting up for sale in the next day or two. They came off my 2013 S5.
