Results 1 to 6 of 6
    Aug 02 2012
    2000 S4
    Harrisburg
    Two front tires need replaced
    I have about 10k on my tires and my front two were slashed.. I don't want to buy 4 tires because I was gonna change my setup in the spring anyways.. So my question is can I replace the front two with used tires around the same tread as the rear? They are the same size and similar load rating but a Goodyear instead of kuhmo.. So does the tread pattern matter or should I be okey? I just need it to last me through the winter
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    yeah you'll be fine doing that
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Aug 02 2012
    2000 S4
    Harrisburg
    now the problem is finding the used ones
    Aug 25 2012
    Elmore alabama
    If you have stock wheels try the dealer for used tires, an Audi or vw dealer may be able to help you but they will try the whole liability thing so have a good story to tell them like I'm in a bad spot and my ex slashed my tires or something. Try to match tread depth and speed rating the best you can.
    Aug 02 2012
    2000 S4
    Harrisburg
    I found 3 pirelli p6 four seasons the guy only charged me $150! They have the same tread depth as my other tires in the rear so they are perfect, and I have a spare now.
    Aug 02 2012
    2000 S4
    Harrisburg
    Quote Originally Posted by s4BoostKing View Post
    And the tire size I needed was a 245/40/18 so I was very lucky to find them
