Well, the ol' 2.0t avant started leaking coolant earlier this year... at first I found the water pump was leaking so I had the full timing belt service done at around 75K. Life was good for a while until a few months later when I got back to the car after letting it sit over the weekend and the coolant light was flashing at start up and the reservoir was bone dry. I couldn't find any signs of leaking or dripping so I topped and it off and life was good again. For the next few months the car would sporadically lose coolant, sometimes more than others. During a recent oil change, my tech found the thermostat was leaking slowly. Yes, we found the issue! Replaced the thermo and the temp sensor however in the recent days after the fix, the coolant level is still dropping without any signs of puddling on the ground.
I'm at a loss here... I've owned vw/audi's for years and never had such a continuous coolant issue. Anyone experience something similar? What other problem areas should I look into? PLEASE HELP!
The victim!
