Results 1 to 14 of 14
    Aug 05 2016
    San Antonio, TX
    2013 S5 Wheels on b8.5 Audi S4
    Hi,
    Looking to grab a set of wheels from my friend. His 19x8.5 ET32 wheels replacing my 19x8.5 ET43. Are there rubbing? Will they fit? Has anyone done this and had or have issues? Thanks in advance for the input.
    2014 Audi S4 | Glacier White | Sports Diff
    Veteran Member Three Rings bayonet14's Avatar
    Aug 07 2013
    BMW 335i
    Pinelands NC
    Aug 05 2016
    San Antonio, TX
    Thanks! I shall read up on that thread.
    Nov 12 2015
    Here
    Quote Originally Posted by kdn0789 View Post
    Are there rubbing?
    Mein ist grau
    Senior Member Three Rings BAHNSTORMER's Avatar
    Mar 26 2010
    Waukesha, WI
    Outside of the wheel will move outward 11mm the inside stays the same.
    Daily driver: 2012 S4 P+
    Phantom Black Pearl Effect / Sports diff / Alcantara / S-tronic / MMI Navi + / B&O / 19" Peelers / Carbon Atlas inlays / advanced key / rear camera / Supercharged badges
    Previous Audis: 1984 4000S Quattro // 1989 200 Quattro // 1994 S4 // 2005 S4 // 2010 A5 3.2
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by BAHNSTORMER View Post
    I disagree. The wheel width stays the same but the center of the wheel moves 11mm farther outboard, meaning that both the outer and inner rims of the wheel will move outward by the same 11mm.
    SOLD 2015 Daytona Gray S4
    Apr 05 2016
    Portland, OR
    The 9th post in that thread....
    Quote Originally Posted by ItsDubC View Post
    I run 19x8.5 et32 on all corners w/ 245/35/19 tires lowered on H&R OE Sport springs and have never rubbed:
    Geoff
    Aug 05 2016
    San Antonio, TX
    Quote Originally Posted by whiped View Post
    Will 255/35/19 work?
    Oct 14 2012
    Empty...for now...
    SE PA
    I ran a set of 19x8.5 et43 wheels with 10mm spacers, making them effectively et33, with Michelin PSS 255/35-19 tires this past summer. Your setup will sit 1mm farther out than this one. The rear passenger side rubbed badly but there is no rubbing on rear driver side, and it looks like the driver side could move out another 1mm without any problem. I might have been able to eliminate the rubbing on the passenger side by having the wheel camber adjusted more negative.
    For your reference, here is the aforementioned setup:
    Front and rear 19x8.5 net offset et33, Michelin PSS 255/35-19,
    no rubbing on driver side rear:
    Major rubbing on passenger side rear:
    Replaced 10mm spacer with 5mm spacer and rubbing went away but didn't look nearly as good:
    Mar 26 2010
    Waukesha, WI
    Quote Originally Posted by SteveYem View Post
    I hate it when I read the calculator wrong.
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Isn't there some info out there about the rear sub frames on some S4's being off-center from the factory? Could be why it rubbed on one side and not the other.
    Mar 21 2015
    Whats funny is you needed a calculator to figure that out.
    - - - Updated - - -
    Quote Originally Posted by KnewJack View Post
    Yes there are quite a few people that have this issue including me.
    Active Member Two Rings jaygemson's Avatar
    Feb 05 2014
    United Kingdom
    Me too. Had the subframe alignment adjusted by my tuner, sits perfect now.
    Audi S4 3.0V6T Deep Sea Blue Pearl [2010]
    MRC tuned, Ohlins coilovers, Team Dynamics Pro Race 1.3s, Milltek non-res, RS5 Brembo 8-pots, RS4-style front, RS5 rear
    Mar 26 2010
    Waukesha, WI
    - - - Updated - - -
    Oh, to be the savant that you are.
