Results 1 to 18 of 18
    Established Member Two Rings Destiny2.0's Avatar
    Aug 15 2014
    Automatic taking too long to shift... why?
    So I've searched through the web and forum and didn't really find anyone with the same exact problem. In both D and S, my car goes up to 3-4000 rpm and then stays there for a few seconds and then shifts. And it takes forever getting up to those rpm's to shift gears. I just recently had a cylinder 3 misfire and got all 4 coilpacks and spark plugs changed about 3 weeks ago. Any input will be greatly appreciated.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    More details about the car please, year, model, miles, what kind of transmission - CVT or TIP???
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Oct 24 2015
    Perth, WA
    When is the last time you changed the transmission fluid?
    My respray thread
    Aug 15 2014
    Its a 2005.5 2.0T quattro. Its the automatic with the ability to put it into manual to shift up and down. Im sorry idk which one that would be considered. And i bought the car used with 87xxx miles and all I've gotten done are the coil packs, spark plugs, and one oil change right when i got the car. I'm at 89xxx miles now. So I would have no idea when the trans fluid was changed. I also have a p0089, i know its a generic code. Symptoms of that are my car taking time to start after overnight, if i keep it running for too long the rpm drops to 500 and stalls out on me until i give it some gas and start driving it. I know those relate to the lpfp and hpfp so idk if these 2 issues can be related.
    Oct 09 2007
    Miele S7
    Quote Originally Posted by Destiny2.0 View Post
    Change the fluid and check for oil residue around the pcv area.
    Aug 15 2014
    Quote Originally Posted by 80sGuy View Post
    Okay, I will get that done first. Thank you!
    Oct 24 2015
    Perth, WA
    Do you have VAGCOM?
    My respray thread
    Jun 18 2015
    DavidhogAJ
    Philippines
    Do a transmission service first: Get the cheaper OLD fill kit from ECS Tuning if you have a cool mechanic who will let you supply parts. That code COULD be as simple as a $50 Diverter Valve and wouldn't have to worry about that part prob ever again. Also try to track down any service records on it. The CarFax, even if you have to pay for it, will tell you a lot like if it got any of the numberous campaign fixes under warranty, etc, including the HPFP/cam follower repair.
    Aug 15 2014
    Quote Originally Posted by danbfree View Post
    The Dv is actually another thing I did replace, I forgot to mention it. And I actually do have a mechanic that lets me brings my own parts. He just doesn't warranty his work if something goes wrong the parts but that's reasonable and I trust Ecs tuning and their parts. I'm gonna definitely look into pulling a carfax on it as well.
    Jun 18 2015
    DavidhogAJ
    Philippines
    Ya, the CarFax alone will tell you where it was sold and serviced and you can always request service records from the dealers/shops with proof of ownership... I tracked mine down after I bought mine and was pleasantly surprised all the big problem stuff was already done under CPO warranty at the dealer.
    Aug 15 2014
    Unfortunately I don't have a vagcom. Does that give a more detailed reason for the cel codes? I've never used one but I'm pretty sure my mechanic might have one considering he owns 3 audis lol
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    Yes it will give you more detailed info, it will list things other scanners will not especially with epc codes
    Also I had a car fax and it was useless, I have seen many that do list the records but honestly mine was probably the least detailed car fax I've ever seen haha all it listed was the mileage and barely any registrations *shrug* it was in the same city its whole life though so I could try he dealership but meh
    Also from what I've seen most mechanics don't warranty their parts
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Jul 25 2016
    new hampshire
    Also, I would change the transmission fluid ASAP, I have a manual transmission of the same year with half the miles and mt's are less affected by old fluid and he difference was unbelievable! I honestly thought I had synchro issues, and as gonna have to replace the gears etc, I changed the fluid and BOOM it was night and day! Honestly it will be really expensive but you need to change the fluid immediately. The longer the wait, the more damage you will cause
    Eric
    Aug 15 2014
    Quote Originally Posted by pezgoon View Post
    I'm gonna buy the transmission service kit from Ecs and have my mechanic do the fluid change as soon as I get some time. I pulled the carfax and there wasn't much. Just the usual oil change and what not. I'm the 2nd owner and The car always went to the same dealership but all the way in Maryland and in in New Jersey so I don't think it's worth it. I rather just fix the issues myself. I really appreciate all the help and input. This is actually my first real post on the forum so I really appreciate the help, thank you so much.
    Oct 24 2015
    Perth, WA
    Just change the oil. Not hard.
    My respray thread
    Jul 25 2016
    new hampshire
    Your welcome, ya once the oil is changed you should be good to go, that sounds like a classic case of needing new fluid
    Eric
    Aug 15 2014
    So just an fyi thing, my car randomly stopped lagging at shifts ever since the cold weather came in. I still haven't gotten time to the fluid change. You think it's just a coincidence or is it cause the cold weather changed the consistency of the fluid or something? I'm still getting it changed but was just curious about this.
    Oct 24 2015
    Perth, WA
    Yes, the viscosity would have changed.
    My respray thread
