Results 1 to 8 of 8
    Jun 29 2015
    Danbury, CT
    Fluid Leak - Seems to be Diff - How Bad?
    So based on stains on my driveway, it looks like there is some sort of leak coming from 3/4 back of the car - basically it looks like it's right around the rear axle. It's not just water dripping on a cold morning, because an old stain is still very visible. Please excuse my blurry pic of a weiner shaped stain, but those occurred on two different nights. Any input?
    Do I need to get the car into a shop immediately? Was going to wait until my 45K service in a few weeks to bring the car in.
    I have a third party warranty - will this be covered?
    Any other possibilities?
    Sport diff going bad?
    Left stain is old - right stain is new; both similar shapes
    Jul 16 2012
    Mid-Atlantic
    Seems like a slow enough drip, but maybe you should just do your 45k service a bit early?
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    I'd take it in. If leaking on your driveway it's leaking everywhere else too (while driving etc).
    Do your 45k early if need be or do it separately. A few weeks early is prob no big deal.
    I'd assume your warranty would cover it.
    Jun 29 2015
    Danbury, CT
    Quote Originally Posted by Works2shoot View Post
    Yea I know terrible pic, I took it at like 515am this morning. That's what I was thinking also, but the next 3 weeks are crazy with work/vacation time, so I'm just not sure if I can actually get there/have no car
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Is it more on the driver or passenger side of the sport diff? It's either the actual diff or the electronic side as both hold fluid, but one is gear oil and the other is atf fluid...there isn't a lot of either fluid so I wouldn't wait unless you want bigger problems. Swipe your finger across the fresh fluid and smell it or get under the rear of the car and see where it's coming from.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Jun 29 2015
    Danbury, CT
    Quote Originally Posted by BlownOne View Post
    It's hard to tell what side it's closer to, but seems to be in the middle. Also, my car is 6MT so I'm not sure if that changes your assessment. I also tried to do the finger swipe, but it must've been there too long as I couldn't get anything to stick on my fingers
    Dec 30 2015
    Sacramento, Ca
    No the diff is still the same in a manual or dsg (sports diff). You should be able to lay down and peek in with a flashlight with the car on the ground to get a better idea.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by amusante View Post
    You didn't mention what model year your car is, but back in 2011, there was a problem with leaky seals on the sport diffs as covered in this lengthy thread. Repairs were covered under a TSB/warranty.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
