Results 1 to 11 of 11
    Senior Member Two Rings audis4culver's Avatar
    Mar 07 2016
    2016 S7, 2011 S4, 1985 VW Vanagon, 2015 Q7, BMW 2004 X5 Manual, 1966 Jaguar E-Type
    Georgia
    Favorite mod with front end off
    I am going from stage I to stage II which we know requires the front end to come off. Also installing a separate charger cooling reservoir while at it.
    What else do you all think is a good mod to do? change out the grill, audi logo.. ??? looking for any cool ideas out there. thanks. Car is a 2011 S4 DSG with 36K miles on it.
    2016 Audi S7
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    yellow fogs?
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Apr 05 2016
    Portland, OR
    Grille if you like the Mesh style.
    Paint the crashbar black
    Install a protective screen
    Inspect everything for leaks, condition of tubing, belts, etc.
    Light bar if you want it
    Retractable plate hider if you want it
    That's about all I got
    Geoff
    Senior Member Two Rings jmaddr's Avatar
    Jun 19 2013
    United States
    A new sway bar would be easier to install with everything out of the way. However, changing the front without the rear wouldn't be recommended (whereas the reverse is not a terrible idea)
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    Upgraded cooling would be the big one.....grille is easy though. I actually went with a Black Optics grille swap instead of the mesh. I like it better than the mesh for some reason on the S4...
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Nov 12 2015
    Here
    Swap out those chrome rings for basic black
    Mein ist grau
    Jun 21 2004
    mpls, mn
    Larger Crank Pulley
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Stone guard for coolers n rads is a good one
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by creativecody View Post
    I agree on the b8.5 for sure
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Does anybody make a decent 8.5 replica grill for B8's?
    Mar 07 2016
    Georgia
    Sweet list!! Thanks. Mine is all blacked out optics so top of list is audi rings to black. Upgraded cooling. Cant seem to find the grille i like. Abt makes a super cool one but havent made up my mind. Your ideas have opened up further options. Thanks.
    2016 Audi S7
