Results 1 to 7 of 7
    Dec 16 2014
    Irvine, CA
    Vacuum Connections
    I am in the process of installing a 2002 Allroad Engine in m 2000 S4, I got most everything connected except these 3 vacuum connections. I bought the car without many of the original vacuum hoses, so I have no idea how it was connected originally.
    The booster connection #3 on the picture, on the allroad is connected to the electric vacuum pump. The S4 doesn't have it, Should I just cut the line and cap it? Is the S4 connection just between the manifold and the booster? Anyone have a picture of that line? Is there a different version of the hose?
    #1 on the picture I am guessing is the vacuum reservoir line, I think it needs to connect to #2, but the lines are in different spot. Any clarifications?
    Veteran Member Four Rings QuinnsterKID's Avatar
    Mar 02 2010
    1989 Ford Mustang LX 5.0
    Las Vegas
    I can send you pics of mine when I get home from work
    2012 Moonlight Blue S4 // Black Optics // Intake and Exhaust // Lowered
    2001.5 Nogaro S4 // 6MT // Stage 3 // K04 // E85 // Daz tuned
    2014 Daytona Gray Pearl Q5 TDI // Black Optics // Sport
    2013 Black A4 Sport SOLD
    2008 Ibis White A6 3.2 Quattro SOLD
    2004 Silver USP A4 Avant 6mt SOLD
    2000 Laser Red A4 1.8 Quattro SOLD
    2001 Santorin S4 SOLD
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    The original brake booster hose tee'd the accordion and manifold to the brake booster. Just rip out the brake booster hose and replace it with a check valve and a hose that goes to the manifold, plug the hole in the accordion.
    Details here -> http://www.audizine.com/forum/showth...e-Booster-Hose
    The other two I can't really help you
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Dec 16 2014
    Irvine, CA
    Quote Originally Posted by CJ_ View Post
    My Accordion does not have a plug, I think the 2000 cars didn't come with a connection there. I'll make a new hose with check valve.
    Dec 16 2014
    Irvine, CA
    What about the suction pump? Both the old style and new style have one in there, can it be removed?
    Oct 27 2014
    Flag/Phx, AZ
    Yes, stick the check valve in the firewall rubber grommet, and run a line to the back of the IM. Nothing else needed.
    This is what the check valve should look like (although probably not yellow), big end goes in firewall
    Some more pics in this thread:
    http://www.audizine.com/forum/showth...r-Hose-Removal
    IG: CJ_s4
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Verify that the line number 1 leads to vacume tank in front fender. If so connect that rubber hose to the black check valve circled in Dark blue and remove the black hardline leading to ur number 2.(in green)
    And as far as 3 goes. Do what they said. Get rid of the stuff I also put in green. And then place check valve where I circled light blue and run Line to intake manifold.
