Results 1 to 29 of 29
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    What is going on? No start after flywheel change
    https://youtu.be/4ewrU5Ntsd0
    I can't figure out why it is doing this. Changed my dmfw for a new aluminum fidanza 11621 and now this. Thought it was my starter so changed that and still happens. What do you guys think? Thanks in advance!
    Sent from my SM-G930T using Tapatalk
    May 16 2008
    WA
    What do you mean by no start? Like the motor doesnt crank, or crank and doesnt fire?
    Can you hear the starter spinning? Can you hear the starter solenoid click? Reconnect grounds and all connections on the starter? You can check the starter relay wire to see if its getting 12v when the key is turned.
    May 22 2013
    Las Vegas, NV
    The starter will engage sometimes, sometimes it won't. First try in video you can hear it crank for a second
    Established Member Two Rings kalyjor's Avatar
    Sep 09 2015
    I was told by another owner that the flywheel has to be marked like the cam gears when replacing the timing belt, something with the teeth of the flywheel lining up to a timing sensor
    Sent from my XT1254 using Tapatalk
    Established Member Two Rings big_jerm's Avatar
    Dec 04 2012
    Massachusetts
    sounds like the starter gears are grinding? does the car have any fault codes?
    Silver 2000 S4: UUC Catback w/o muffler. Lowered on H&R's. Independent fogs & rear fog mod. App Radio touch screen deck. 100W amp and sub.
    May 22 2013
    Las Vegas, NV
    Thanks for the the input guys. As far as codes go, I can check in the morning.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Never seen it, but heard the starter can get hung up on its locating dowel and do weird shit.
    You put the bellhousing spacer back in?
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    ]Your starter is misaligned.
    I like zillarobs suggestions.
    Here is what that dowel looks like on my spare motor, i believe this is the wrong position as it dosent align with my starter. Others have noted that this is the correct position for the dowel. Perhaps it was too rusty for the starter to fit
    I dont know if you could get the trans all the way in without the spacer however!
    Dec 17 2014
    San Diego CA
    Quote Originally Posted by kalyjor View Post
    Flywheel only bolts on one way. If he got it on the crank and all the bolts in, it is aligned properly.
    You are correct, the 60-2 wheel does need to be aligned with the VR sensor in a proper spot to run properly.
    Useless info for this thread but, each tooth is 6 degrees apart with 2 missing teeth. the missing teeth indicate to the ECU what cycle the motor is currently on.
    i think the alignment is 60% before cylinder 1 TDC if i remember properly. I havent verified this with Automatic 2.7s, only manuals as the VR sensor is in a different spot on the Auto trans
    Nov 16 2010
    WetSide, WA
    That dowel looks right to me?
    My guess is people munch them when putting in an engine stand? My buddy did it some how, but I wasnt there to see the how or why.
    You prob right on the spacer, just throwing it out there
    It prob takes effort, but people have put fidanzas on wrong before.
    I doubt that is what is going on here though.
    It would crank over fine, but have cel and cam codes.
    Dec 17 2014
    San Diego CA
    Quote Originally Posted by zillarob View Post
    I think you perhaps might be actually right in regards to the dowel needing to be pushed all the way out.
    When i checked compression on that spare motor i had to hammer the dowel flywheel side to get my starter to mount properly however.
    I was actually having the same problem as OP with the dowel in the wrong spot as shown above, the starter kept grinding against the teeth of the flywheel when trying to engange even if it was just off by a degree and i couldnt get my starter mounted on that dowel.
    i dont want to pull the starter out of my running car just to look at the dowel to know the real answer though lol
    Looking at the starter on ECS,
    I see the provision for the dowel
    https://www.ecstuning.com/b-bosch-pa...rter/sr0422kt/
    Maybe the misalignment is occuring on the bottom bolt with the wrong bolt being used or something.
    Nov 16 2010
    WetSide, WA
    Ya, pretty sure that dowel is supposed to stick out like that on the starter side.
    I have a big nut that I use when putting in the stand so I dont muck it up.
    The only one I have seen down there myself is the starter running into the wg can. Stuff gets real tight in that area, especially with bigger turbos.
    Clocking has always gotten it by on k04 sized turbos, but had to do some detail grinding on the starter to clear the can on 770s.
    Never installed k24s so not sure how they line up.
    Apr 07 2011
    Home of the mighty beaver
    do make sure you didnt knock the trigger wire on the starter loose... mine had a broken retaining clip and slid off just enough to break contact.
    Active Member Four Rings
    Sep 14 2009
    s.e. mass
    Quote Originally Posted by rguil View Post
    I've seen dummies blast on the cheap aluminum flywheels incorrectly, thinking they are clocked properly, only to oval the bolt holes to the crank. Lack of knowledge is a killer...
    IG: @PB5S4
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    the fidanza flywheel has slightly looser tolerances that can allow you to install it 180 out. I did exactly that with mine and cranked forever with no start. from the sound of the video though something isn't spaced right. I never got that grinding sound on mine when it was backwards.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    May 22 2013
    Las Vegas, NV
    Thanks for the help guys, I will getb under the car and see if I can adjustv the starter at all. I did see the dowel and made sure I got it on there.
    Dec 02 2009
    Northern Virginia
    I ran into a similar issue with my car. One of the spline/dowel got pushed in (toward the transmission) so the starter did not align perfectly. The starter gear was able to pop out and crank the flywheel but it wasn't able to retract because of this slight mis-alignment.
    Try turning your crank pulley by hand using a ratchet to see if you can easily turn it. In my case, I could NOT.
    Thread on my issue: http://www.audizine.com/forum/showth...grinding-noise
    May 22 2013
    Las Vegas, NV
    May 22 2013
    Las Vegas, NV
    Looks like my pp was rubbing inside the bellhousing
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    Did you happen to measure the installed stack height of the new clutch and flywheel?
    2005 A4 Avant 1.8t QTM
    May 22 2013
    Las Vegas, NV
    No but today after I took everything out, the flywheel is actually thinner than stock. I think I had it oriented wrong to be honest.
    Nov 16 2010
    WetSide, WA
    If you have it at tdc, the -2 window will be up near the dside turbo at like 10-11 o'clock.
    What clutch setup you have?
    May 22 2013
    Las Vegas, NV
    Fixed it. Right now using a spec pp and a 6 puck clutch.
    Nov 16 2010
    WetSide, WA
    Is that the right tob? All the spec clutches I have installed used the thicker tob.
    The one in your pic is for a luk oem style pp and wont work with the sachs pp many use.
    May 22 2013
    Las Vegas, NV
    Damn!
    May 22 2013
    Las Vegas, NV
    Nov 16 2010
    WetSide, WA
    You good on the tob, that is a luk pp.
    I have only played with the 3+ with the sachs pp.
    Dec 17 2014
    San Diego CA
    Quote Originally Posted by Royal769sr View Post
    That clutch looks used. Did you reset the SAC before install?
    May 22 2013
    Las Vegas, NV
    Yeah I did
