Results 1 to 11 of 11
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Track-worthy Coilover Setup?
    Im still not satisfied with my suspension setup. Ive tried coilovers by ST, a b8 suspension setup with neuspeed race springs. The st setup was too soft and poor adjustability as they didnt go too high in the rear for the winter. The neuspeed still has body roll in the corners and a little too bouncy for what it is. Now i know that if i dont want a bouncy ride i should probably stick with an oem setup, but i like to take my corners aggresively and will be tracking the car eventually.
    So far ive looked into the stasis ohlins challenge suspension and it looks good but I cant find it anywhere. Are there any other alternatives with linear rate springs besides pss10's?
    I need something the offers good adjustability. Ive also looked at kw v3 which seems to be popular.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Mar 24 2013
    Oakdale, CT
    I would probably go KW V3s myself. I don't personally need anything track worthy, so my KW V1s are just fine.
    You won't find the Stasis setup new anymore since Stasis went tits up, but I've seen used sets here and there.
    -Adam
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Try higher end coilovers like Bilstein PSS9 or what aluthman said.
    Never heard of the PSS10 for b7 application.
    Be sure to get the right suspension for your car specific to AWD vs FWD, 2.0T vs 4.2, etc...
    Get a stiffer front and especially rear sway bars. That will help a lot with body roll and cornering. The b7 stock sway bars are weak. Most guys here pick up the rs4 sway bars for a well worth cheap upgrade. For tracking I would personally with go stiffer H&R or Hotchkis or 034
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Jan 24 2008
    Pennsylvania
    The Stasis Ohlins and Ohlins Motorsports are still up at the top. YOu can pick up a set for pretty reasonable price, and they are fully rebuildable. PSI in California rebuilds them and even provides dyno sheets for before/after rebuild performance. Used sets come up from time to time.
    That said, the KW V3 and Bilstein PSS9 and 10 are both very capable contenders. But not on the level of the Ohlins.
    If you're baller, go with the Ohlins TTX, probably the best available out of the box. Be prepared to spend lots of $$$ though.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    May 09 2012
    Virginia
    Quote Originally Posted by Sanjman View Post
    I have KW V2's on my Avant with Hotchkiss sway bars. It handles quite nicely. If you are really looking for a track setup though you are going to need to spend some money. KW V3 as Aluthman mentioned or Bilsteins PSS10 mentioned by Sanjman would be decent choices with the sway bars of course. Ohlins if you can find them are unbeatable. Adjustable control arms and links will allow you to dial in camber and what not. Suspension is where you need to spend your money if you are serious about going to the track.
    Nov 16 2006
    Skokie, IL
    Just an FYI camber kits like the adjustable control arms aren't enough to fully dial in camber on most lowered b7s. They simply don't have the clearance to adjust it to get the optimal camber. They help but not enough to get the calibration all in green during alignment
    Jan 06 2012
    Chicagoland
    talk to these guys, they can help you out: http://www.fatcatmotorsports.com/
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    I haven't tracked mine yet, but koni coilovers, rs4 rear bar, 034 sway bar links all around. It's ridgid, very tight steering (s4 rack and I believe the 628 relay will lower the ratio not sure if true but that's the number off the rs4 rack relay). I think mine will handle the track very well.
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    I have PSS9's on my Avant, and on my P car. They are not a track coilover, they are a street coilover that does OK on the track. Ohlins or KW V3 are track stuff.
    "Obsessed" is a word that the lazy use to describe the committed.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    I have a set if Stasis Öhlins Challenge coilovers and love them for street use. They'll be seeing limited track days next year and I suspect they'll do the job. They are rebuildable, and highly capable.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    What are your guy's thoughts on BC Racing coilovers with custom rate Swift springs? I'd love to have Ohlins, but for the price of those I think I'll buy a few more B5s instead...
