perhaps this belongs in the questions I'm too afraid to ask category but here it goes
1.8t with IE rods and JE pistons motor built in Salt Lake City in 2010. bought car in 2012, spoke with the mechanic who did the engine work and he said the motor was built loose to handle high boost.
when I got the car it had the 034 vortex catch can that had a filter on top venting to atmosphere. It would always leave any oily residue mess around itself and would stink. This spring I finally rerouted the crank case/valve cover back to the TIP with a Saikou Michi catch can using 3/4" lines and the pcv pancake valve between CC and TIP.
I still get the oil smell inside the car, the catch can just blows oil straight out from the drain.
Im curious if the drain could have a bad seal or if there is too much pressure going through it.
oil consumption does not seem to be an issue, just under the full mark after 3000 miles and never see drops on the ground
do I have a problem? CC is mounted at passenger side in front of shock mount, pretty level with valve cover
