Results 1 to 40 of 69
    Jun 08 2008
    Calgary AB Canada
    Spark plug and oil choices
    Hey all,
    I'm coming from a B6 with a built 1.8T so trying to gauge what people are running in their 2.0Ts these days. Tried searching the forums but had little success finding a definitive choice.
    I would always run Rotella T6 5W40 or 0W40 in the B6 and was quite happy with it.
    As for plugs I would run NGK BKR7E's with a GT3076R, and when it was stock I ran one heat range warmer, BKR6E. This choice came from a great post over at audigeeks - http://myfastgti.com/volkswagen/thre...eat-Range-Info
    The question is, are these choices still valid for the 2.0T?
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    May 24 2007
    PA
    I run BKR8EIX plugs on GIAC Stage 2 tune.
    For oil I get a 5 quart jug from Walmart of Mobil 1 0W-40 for $25 bucks and a factory oil filter from the dealer for around $15.
    There are 100's of post in regards to the many options. It comes down to personal preference and budget.
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    I'm running the same BKR8EIX plugs as above, gapped at .022 and have been using Rotella T6 for the past 3 oil changes. I'm APR stage 2 and running e85 almost 100% of the time, it's been solid.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Nov 23 2014
    '05 infiniti G35 coupe, '12 B8 A4 avant quattro
    Socal
    Ditto on Mobil1 0W-40 from walmart, but I usually order my filter from amazon. As for spark plugs, I would check what ECS use for their ignition service kit.
    Senior Member Two Rings BrianVan's Avatar
    Apr 03 2015
    Naperville, IL
    Mobil 0w-40 for $25 and got a $12 rebate once from Walmart....ordered a 5 pak of MANN filters from ECS at $10-11 a filter and their ECS bolt plug with magnet and brass crush washers. Wasn't too confident in their hex bolt and the fear of it stripping out. just changed it for winter here in chicago and runs great...plugs..unknown...picked my 2013 up a few months ago off a lease.
    Jul 27 2016
    Louisiana
    Does everyone here who does there own oil changes also have a Vag Com? Or do you ignore the service light?
    Senior Member Two Rings LmG7119's Avatar
    Jun 03 2014
    MNN
    Quote Originally Posted by rainydaze View Post
    I don't think you need Vag Com if you have MMI 3g http://mr-fix.info/audi-mmi-3g-reset...rval-reminder/
    Feb 02 2016
    Quote Originally Posted by lepa71 View Post
    MMI only reset regular oil change but not service interval at 15k 25k 35k etc...
    Established Member Two Rings TVP125's Avatar
    Dec 14 2015
    Palm Beach, FL
    NGK BKR8EIX plugs with Castrol 0w-40 no issues.
    12 Audi A4 S-Line
    EURODYNE FrankenTurbo F23L
    K&N Typhoon Intake
    Magnaflow Sport Series 3" Turbo Back Exhaust
    Treadstone TR8L Intercooler
    ST Coilovers
    Senior Member Two Rings TurboNate's Avatar
    May 16 2015
    El Cajon/CA/San Diego
    You can use Carista and it will reset service interval
    2009 A4 Premium+ Quattro
    APR Stage 2 | CTS Turbo High Flow Cat | Custom Intake System | AG 19x9.5 m580 w/ 10MM Spacers In Rear | RS Mesh Grill | 5% / 20% tint
    AKA: NathanMansoor
    Jun 08 2008
    Calgary AB Canada
    Those of you using iridium plugs, whats your change interval?
    Stock. For now...
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    I use Liqui Moly 2332 Leichtlauf High Tech 5W-40 Engine Oil - 5 Liter https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2014 SQ5 P+ | 034 Stage 2 ECU + TCU | 034 190mm crank pully | 034 Street Density motor mounts | 034Motorsport S34 Carbon Fiber Intake | Merc Racing HX V3 | Bilstein B8's w/ H&R Springs | 034 Trans insert | RSNAV 10.25
    NEW EDM MIX APRIL 2021 https://soundcloud.com/matt-scheinwa...in-my-basement
    Veteran Member Three Rings TwinTipSkier's Avatar
    Nov 18 2009
    2012 VW Sportwagen 2.5S
    Tampa, Fl / Boston, Ma
    Rotella T6 5w40 & NGK BKR8EIX, change em every ~15k
    Change my service interval via MMI.
    Another former B6er! Hiya. You miss it yet? These B8s are nice, but I tell ya... nothing compares to a well built B6... (just me being nostalgic)
    -John
    IG: johns550cc
    | '12 A4 Avant Brilliant Red | Thread |
    | '02 A4 1.8TQMS -gone |
    Veteran Member Three Rings B8_Dude97's Avatar
    Sep 05 2016
    Antioch, California
    Castro synthetic 0w-40 and NGK BKR8EIX. With a oem Audi filter for 12 bucks Amazon prime
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by TwinTipSkier View Post
    Same here.. miss my k04 b6 on pss9's best setup!
    Running castrol edge oe , mixed with liqi moly ceratec, and same ngk bkr8eix plugs!..
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    Motul 8100.
    /end thread
    My current rides...
    Audi
    Jetta
    Jun 08 2008
    Calgary AB Canada
    There are definitely things I miss about the B6, but I was getting really sick of fixing things. It's nice to just get in the car and drive sometimes...
    Quote Originally Posted by Jacon View Post
    Motul 8100.
    /end thread
    Not really, you didnt say anything about spark plugs...
    Stock. For now...
    Veteran Member Four Rings Zach L's Avatar
    Feb 24 2010
    Austin, TX
    Quote Originally Posted by ILVTRANCE View Post
    x2
    That's what I run in my daily driver. Recently switched to it from the Liqui Moly 2041 Synthoil Premium, which I had great results with for about 3 years running it in several of my cars. In the same cars I tried Mobil-1, Pentosin and even ran some ester-based oils from Redline and Motul. Not a fan of the ester oils for a daily driver anymore.
    I used to run the Rotella in my Corrado, Mk3, etc. but I would NOT consider it an 'advanced' oil. It does not have the additives of newly developed, long-life oils. I consider Rotella to be basic in that sense compared to Liqui-Moly and other newer, german-made synthetics.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    Quote Originally Posted by Zach L View Post
    x2
    Why?
    My current rides...
    Audi
    Jetta
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    Quote Originally Posted by onceover View Post
    NGK BKR7s. The BKR8s are too cold
    APR stg II
    My current rides...
    Audi
    Jetta
    Feb 24 2010
    Austin, TX
    Why?
    While they were great when fresh, seems like they would break down much quicker than the Pentosin and Liquid Moly. I'm not sure of the science behind it, but the engines were audibly much louder at startup with the higher ester oils, especially the Redline. Sounded like the rod bearings wouldn't get as much oil for a few seconds. This was not a one time test; ran these more expensive oils several times. While I know these oils will be more stable during track days or hot-temp canyon driving, I was not a fan. My belief is they're superior in racing applications but lack the long life characteristics that are preferable in a daily driver. Whether this results solely from the additive pack differences, I do not know.
    Sep 03 2012
    Lehigh Valley, PA
    APR stg II
    Maybe for older b8's.. but definitely recommended for flexfuel b8.5s running e85 stg2 tunes!
    Senior Member Two Rings NRigs's Avatar
    May 21 2015
    Ma
    I am am using PRF8S8EG on stage 1. No issues whatsoever. I also have a b8.5.
    2020 SQ5 Prestige | IE Stage 1 | BMC Air Filter | 034 Transmission Insert
    Gone:
    2011 335xi | Custom Tune | Meth | VRSF DP | VRSF 5" Intercooler | VRSF Chargepipe | BMS Intake | xHP Stg 3
    2014 A4 | CTS K04 l Euro Code HFIP l TR11 l 034 Mounts & Inserts l ECS Luft-Technik l DV+ l LED Light Swap l R8 Coils l NGK plugs l RS4 Grille l Niche Targas M129 l Continental DWS 06 l CR-15
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    Well, I change mine every 5K and haven't notice those problems. In fact, the Motul solved my oil consumption problems.
    My current rides...
    Audi
    Jetta
    Aug 17 2015
    California
    APR stg II
    Arent 7's cooler than 8's???
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    Quote Originally Posted by A4x View Post
    no
    My current rides...
    Audi
    Jetta
    Established Member Two Rings Dr. Awesome's Avatar
    Aug 22 2014
    2009 Chevy Silverado, 2011 Yamaha FZ8
    United States
    I'm running Mobil 1 0W-40 Euro, my NGK BKR7EIX are coming today. Running stage 1 tune.
    Aug 17 2015
    California
    no
    Just confused, because the BKR7s say they are a colder heat range than stock. And they are 7's.
    Jun 08 2008
    Calgary AB Canada
    See link in my original post
    Stock. For now...
    Sep 03 2012
    Lehigh Valley, PA
    Stock is 6 , 7 and 8 colder... 8's are recommended for apr's stg 3 applications, and k04....
    Senior Member Two Rings Demringstho864's Avatar
    Sep 26 2015
    Syracuse NY
    motul 8100 every 5000 miles, i also run copper plugs and replace them every 5000 miles. My car runs better with them. copper displaces heat better then platinum or iridium plugs. Plus there dirt cheap.
    2009 A4 2.0T Quattro Premium Plus
    Static dropped on 20s, lots of bolt ons, and some appearance stuff
    Feb 24 2010
    Austin, TX
    I was surprised to find 7's in my stock A4. Purchased the car in April with 52,000 miles and just put new plugs last week. Any reason a non-chipped car would have 7's?
    Feb 24 2010
    Austin, TX
    Quote Originally Posted by Demringstho864 View Post
    x2 on the plugs
    Copper is superior to any other plug, including iridium and platinum. It conducts electricity better, but just doesn't have the longevity. That's the only reason to use other metals... for the longevity. If people want the best plug and don't mind changing often, they should be running copper. Cost ends up being similar or cheaper, just not as convenient.
    Jun 08 2008
    Calgary AB Canada
    I ran coppers in the B6. With how cheap they are and how easy it was to change them there was really no reason to run the iridium or platinum ones. Glad to hear it's the same case for B8 guys.
    Stock. For now...
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    NGK BKR7s.
    Copper (BKR7E) or iridium?
    ...i also run copper plugs...
    Which ones?
    I'm debating on my Allroad (APR 91oct Stage 1) on the BKR7E's or the BKR8EIX's.
    I lean more towards the BKR7E's due to lower cost, easy availability and I don't mind the more frequent change intervals. Thoughts?
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    Jan 01 2017
    Iowa
    I use the Filters from ECS Tuning for $10-11/each. Castrol Syntec (full synthetic) 0W-40 or 5W-40. Amazon sells engine and cabin air filters under $20 and they fit. Amazon has the Bosch Iridium plugs 4 for $27.
    Nov 12 2016
    Fl
    During my 35k maintenance, the dealer listed 4x 06H-905-601-A Spark plugs in the invoice
    A quick google search lists said part as NGK PFR7S8EG
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    From NGK:
    "Copper spark plugs" is a term mistakenly used for a standard or traditional spark plug. A standard spark plug traditionally uses a nickel-alloy outer material fused to the copper core. Some plugs include a coating or pad of precious metals such as iridium or Platinum to extend plug life. But as a general rule of thumb, all spark plugs utilize a copper core.
    https://www.ngk.com/glossary/8/spark-plug/C
    Sep 03 2012
    Lehigh Valley, PA
    Quote Originally Posted by audrobotic View Post
    From NGK:
    Great point and find!.. I guess ECS tuning calling the NGK iridium7 plugs iridium core is completely incorrect...
    Jun 30 2014
    West
    Quote Originally Posted by hyperunion View Post
    Thanks. Yes. The BKR7EIX Iridium Plug has a copper core. Per the NGK website product description the "Copper Core Aids in Heat Removal." https://www.ngk.com/product.aspx?zpid=9352
