Results 1 to 8 of 8
    Oct 31 2016
    Denver
    Advice for buying 2012 S5
    Hello All,
    I'm new here and I'm looking at a used 2012 S5 4.2L 6MT coupe with approx. 32,xxx miles. I'm wondering if you all have any tips or advice on what to look for as far as issues go and any common complaints, other than carbon build up. I'm having the car inspected later this week and have reviewed all service records available. I would greatly appreciate any advice!
    Thanks in advance!
    Veteran Member Four Rings DreDay's Avatar
    Apr 25 2010
    Morris County, NJ
    There's plenty of topics on this via the search button my friend.
    This motor is strong. Issues I've had include:
    Fan motor
    Motor mounts
    Window regulator
    Control arms
    Other than that, great car.
    CURRENT| C7.5 A7 TDI [MODS INCOMMING!] + 958 Cayenne Turbo
    PAST| Bagged MK1 R8| B8 SQ5| B8 S5| B6 S4| B6 A4| C5 Allroad| (2) T2 Touareg V8| Gen 2 Cayenne S
    NEXT| Another Stance Project
    Oct 31 2016
    Denver
    Thank you for the fast reply! I plan to play around with the search function later tonight. Can you elaborate on the control arm issue? And how difficult/expensive was it to replace/repair the motor mounts?
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    2010 bought at 29k, now 68k and I still absolutely love it. It can be expensive to maintain if any issues do come up so I'd suggest to find a good independent european/audi specialty repair shop. I can turn a wrench and have done plenty of my mods myself. Some of the tougher jobs require special tools and time that I just don't have so that's where I don't mind paying a little extra to make sure that the job is done right. My indie can typically do a job at half the cost of what my dealer would charge.
    Things outside of general maintenance:
    Fan motor ~ 50k ($400 parts and Labor)
    Clutch, Flywheel, etc ~ 62k ($2,250 parts, $1,000 labor)
    Wheel bearing ~62k ($400 parts and labor)
    Motor mounts ~ 67k ($400 parts, $550 labor)
    Yes, that's roughly $5,000 spent in the past 17k miles (a little over a year) to keep my car running the way it should be. Mods are a whole different story.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Glove box is too small, so it's hard to fit all the panties that drop. S5 and RS5 problems...
    2013 Audi S5 - EPL Stg 2 ECU/TCU
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Oct 31 2016
    Denver
    Quote Originally Posted by SLU_S5 View Post
    Damn! That's a pretty hefty bill. You mention you can turn a wrench--I tend to do my own maintenance and repairs, as well--did you happen to look into how much of a pain fixing the fan motor, wheel bearing, and motor mount issues would've been (clutch & flywheel are probably engine-out, I'd guess, and I don't have a hoist and space to do that)?
    Also, does your username mean you're a SLU alum?
    Oct 31 2016
    Denver
    Quote Originally Posted by HazeMyth View Post
    Good thing they have a fairly sizable trunk!
    Sep 06 2014
    Rochester, NY
    Quote Originally Posted by jhlrs2 View Post
    I don't expect to pay that much every year - just seemed like this year was one of those "when it rains, it pours" kind of years for my car. Clutch and Engine mounts are some of the big "wear and tear" jobs that would've had to get done eventually suppose. Probably could've waited a little longer for each but I'm obsessive with my car and like to make sure it's running optimally all the time.
    The fan motor should've been an easy DIY but I couldn't get the motor to finally twist out for whatever reason after fighting with it for a few hours. I didn't want to break anything it so I took it in. The motor itself was the biggest part of that bill.
    Wheel bearings shouldn't be all that bad but I don't have access to a press so I didn't mind paying the 2 hours of labor to keep my hands (and garage) clean.
    Engine mounts require either a hoist or engine support. Couldn't find a good instruction guide for the V8 (there are a few for the V6). Probably could've done it myself but I got lazy and just wanted it done with so I dropped my car off in the morning before work, and picked it up later in the evening. A buddy of mine has an A5 and did his mounts by himself - said it was time consuming, but not all that hard. Not sure how different it is for the V8.
    And yes, St. Lawrence University! Laurentian for Life!
    IG: @SLU_S5
