Results 1 to 10 of 10
    Dec 20 2006
    CAN
    RS7 OEM Wheel/Tire weight
    Just changed from summer to my winter setup and christ those oem rims are heavy. One of these days i'm going to pull something getting them stored up in my garage.
    Summer - OEM rims/rubber
    Winter - hartmann 20" with dunlops wintersport 3D. Much lighter than oem 21".
    Does anyone know how much the summer combo weighs? I don't have a scale at home. I swear, i'm going to order a new summer setup this winter and hopefully save some weight and improve performance/looks.
    Cheers
    emilyPay.com - Revolutionizing payment processing by making transactions simple, secure, and more reasonably priced.
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Healiner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    According to this post in this thread, each Peeler-style wheel rim (19" x 8.5" size) weighs in at 28.5 lbs. Your 21-inch Peeler wheels will weigh a bit more. The next poster weighs the tire/wheel combo and it came out as 53 lbs each. Your 21-inch summer wheel combo will weigh more than that.
    Follow-up: This guy weighed his 21-inch OEM RS7 tire/wheel combo . The result is 68 lbs. per combo.
    Current: 2016 S5 in Sepang Blue with Technik Package.
    Dec 20 2006
    CAN
    Quote Originally Posted by plat View Post
    68LBS...well that makes sense. thanks for the info! i forgot all about that post...
    Dec 19 2015
    GVRD, BC Canada
    Quote Originally Posted by CanuckRS View Post
    Now you know how fit you are
    Veteran Member Three Rings scott99c2's Avatar
    Oct 11 2014
    Nashville, TN
    Egad. That's awful!
    Scott
    2013 S7 | Prestige | Estoril Blue | Lunar Silver | SRM RS7 +4mm Turbos | SRM Short Intakes with RS7 Airbox | DS1 Stage 4 ECU | APR TCU | AMS Catted DPs | AMS Cooling Package | OCarbon Large Weave Carbon Package | Alu Kruez | Eurocode Sways | HRE FF01 20 X 10.5"
    2021 SQ7 | Prestige | Black Orca Metallic | Black Optic | Luxury Package | Laser Lights | Tow Pkg |
    Jan 09 2013
    UK
    Winters look good. Out of curiosity did you notice what size the OEM 21's are as in rim width and ET? I believe they are 9.5Jx21? But note sure on offset.
    Dec 19 2015
    GVRD, BC Canada
    Quote Originally Posted by P_G View Post
    According to this Audi/VW wheel website, the 21" wheels are 9 x 21, ET35 (offset). The info on the webpage is for the21" rotor-style wheels but the specs should be the same for the 21" Peeler-style.
    Jan 09 2013
    UK
    Ideal, ta
    Feb 09 2016
    Houston
    That's consistent with my result. Stock S8 21X9 rim with no tire weighed 35 lbs. New tires (PSS 285/35/21) weighed 29 lbs each unmounted.
    2014 A8L 4.0T - RS7 Turbos, DS1 Stage 3 Tune, Full E85, Stock Downpipes, Stock LPFP. [email protected] mph
    Active Member Two Rings apexi's Avatar
    Dec 14 2015
    YVR
    I've weighed them. The stock tire is 24lbs, stock rim 44lbs.
