Results 1 to 6 of 6
    Sep 22 2016
    Florida
    2.7t k04-025 026 Rebuild kits
    Need a pair of rebuild kits for k04 turbos
    Veteran Member Three Rings e30mclow's Avatar
    Feb 08 2015
    An Irishman living in Canada
    I just bought a pair of brand new K04 CHRAs from ProjectB5 for $935 delivered, which was about the going rate.
    I was looking at rebuild kits, and there were a few vendors that popped up when I googled it.
    Current: 1998 Mitsubishi Pajero Evolution
    1990 BMW E30 with 1JZ
    Previous Bad Ideas: 2000 Black Stage III (BW-K04); 2000 Imola Stage III (BW-K04)
    Previous "Better" Ideas: Euro e30 m3, Euro e34 m5, Inca Orange 2002Tii, '89 325iS, '89 318i, '90 318iS, '91 318iS, 2 X '87 316, '89 320i, '81 316 and so on..
    Veteran Member Three Rings 2000s4_m's Avatar
    Sep 05 2012
    2005 vw touareg 4.2 V8
    Mcallen, tx
    Quote Originally Posted by Jl97 View Post
    There is a set of borgwarner k04 chra's on ebay for $820 shipped, dont recommend you do a rebuild yourself unless you have access to a vsr balancing machine
    Sep 22 2016
    Florida
    Having midwest balance my turbos
    Sep 05 2012
    Mcallen, tx
    You can get oem borgwarner rebuild kits for like 100 each, also g-pop rebuilt kit seems to be good for like 110 or 120 each. If you are going to rebuild i suggest you disassemble yours first and make sure they are rebuildable. Sometimes bearings hit the housing or spin and little and worn out the inner housing
    Aug 12 2012
    Indiana
    I have a pair of Chinese CHRAs that I will sell you for $250. They are reported to work fine. I have never tried them. Same CHRA as they use in the frankenturbos.
    Charles
