Results 1 to 21 of 21
    Dec 23 2012
    New York
    Is there an aftermarket spare tire that is lighter weight ?
    Hi. The stock spare is so heavy. Any lighter weight options that fit in the same spot? I don't want to remove the spare.
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by ninsei View Post
    why
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Jun 28 2016
    US
    ^^^ lol, that's basically what the RS5 has in the trunk instead of a spare. haha
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Quote Originally Posted by doug97gxe View Post
    why
    +1 - just remove it. Unless you're driving in some very remote areas you can get someone to bring you the spare if you need or get a tow. (if you're that concerned with weight)
    Quote Originally Posted by fitzydude View Post
    Exactly
    Nov 12 2015
    Here
    Lightening up the rear is going to make the already bad weight bias on this car even worse.
    Mein ist grau
    Nov 10 2014
    Apex, NC
    I honestly want to know he is going with this before i offer my suggestion
    Present:
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    could knock .0001 second of your 1/4 mile time with a lighter spare tire & wheel. look, these are not 1500 pound old Lotus Elans. You'd have to shave a few hundred pounds off the car to notice any performance gains on a near 4000 pound car. even then. I can not notice any change in acceleration with an added passenger in my S4.
    Aug 06 2015
    MA
    You're better off going on a diet
    Jan 10 2014
    2012 a4, 2015 s4
    TX
    Last time anybody here has had to use the spare? For me, 20yrs+ of driving, I've only had to place a spare on once, and that was for my friends car.
    Aug 06 2015
    MA
    Popped 3 winter tires last season, so yes. Montreal, Boston, vermont
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by mintytoo View Post
    I did in July when my wife's A5 had a rip in the tire.. she called me i went to her job and the tire was flat.. i know the tire was an issue so i had bought her a slime compressor portable kit.. .tried to put air in it and it wouldn't take.. looked at the tire it had a slash on the inside.. spare came in handy
    Present:
    Veteran Member Three Rings BJYorko's Avatar
    Jun 02 2015
    Minneapolis, MN
    Quote Originally Posted by mungie View Post
    yeah, I haven't had to use the spare on this car yet as this will only be my second winter with it, but a spare tire is very useful in MN in the winter as well. Over the course of my driving life (roughly 15 years) I've needed the spare twice, and both were in the winter.
    Current: 2017 S6 Prestige | Mythos Black | DS1 stg 1 | mods in progress
    Sold: 2014 S4 P+ | Phantom Black Pearl | DSG | Loaded | lots of mods
    Sold: 2010 S4 Prestige | Phantom Black Pearl | 6MT | loaded | lots of mods Link to Build Thread
    Dec 23 2012
    New York
    Quote Originally Posted by BJYorko View Post
    Trying to save a little weight. But I didn't want to remove the spare cause I thought it was there to help in case of rear impact? But I guess not if the RS7 doesnt have a spare.
    Oct 30 2006
    B8 A4 Avant 6spd
    The spare weighs something like 10lbs? If that? How is that heavy? I remove them one handed...
    -18 718 GTS
    Dec 23 2012
    New York
    Quote Originally Posted by Militant-Grunt View Post
    The one in my car is a lot heavier than 10lbs.
    Nov 10 2014
    Apex, NC
    Is this a performance thing or you having to lift it thing? Because the performance gains are minimal at best especially with these cars when they are so temperamental to engine heat and ambient temperature
    Present:
    Mar 12 2014
    Long Island, NY
    When i go to the track I simply remove it before I go down the strip and leave it in a friends car.. or I use it to keep the canopy from flying away..
    2013 B8.5 S4| APR Stage 2+ w/ UltraCharger on E40 | APR Dual Pulley | APR DSG Update | APR CPS | Awe Non-Resonated Downpipes | JHM Test Pipes | AWE Touring Exhaust 102mm | Alu-Kruez | JHM 2-Piece F&R | H&R Sport Springs
    Senior Member Three Rings Victor Newman's Avatar
    Oct 26 2014
    NC
    Just removed mine for weight reduction. Removed the spare wheel/tire, jack, tools, etc. Left the foam divider, and put two cans of fix-a-flat in there and a full tire repair kit with plugs and patches. Definitely removed a lot of weight from the rear. I can feel the difference back there.
    I'm looking at replacing the behemoth battery with a 9.5 lb. Braille battery. I ran the 6.9 lb. Braille in a previous car with no problems, but that was a 4-cyl turbo. I'm thinking the 2.6 lb difference isn't worth losing an additional 286 cranking amps and a bit more battery capacity. From my research, the stock battery is somewhere around 50 lb. Taking another 40 lb. out would be great.
    I'm not sure how removing weight from the rear would adversely affect the balance of the car. Even though the spare, jack, and battery are cantilevered out behind the rear axle, by removing it, you're not really adding anything effectively to the weight over the front axle. All you're doing is keeping the weight over the front the same, while decreasing the moment of inertia, as far as I've thought through it. No use having to accelerate additional mass in the rear. If it's lighter, it'll be more willing to rotate, and feel should be improved.
    Playing devil's advocate, I don't think ADDING another 75 lb. to the trunk while keeping the stock big battery, spare, and jack would help handling.
    2010 S4 / 6MSG / Sport Diff / Alcantara Interior / StopTech 380mm BBK / Hawk HP+ / Castrol SRF / SRP Pedals / H&R Super Sport / VMR V710
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    I recently had two flats in one day. Had to miss the Drake concert cause I was sitting on I75, 2 hours from my house and 1 hour from my destination, waiting for a tow. I'd say I regularly have a flat about every 3 years. Do you replace your tires every other month?
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Jan 10 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by Charles View Post
    Jeez, that's bad. Two flats, huh? Then one spare tire wouldn't have helped you anyways, lol.
    I usually have to replace tires every 2-3 years. Occasionally get a nail but it's easily patched.
    Knock on wood.
