Hi all,
First post here. I've been lurking for some time now trying to figure out my problem, no luck. Here's where I'm at. Hopefully someone has a suggestion on where to go from here.
Problems
A) Car will start after sitting overnight or for about an hour after failure.
B) Car will not start at all.
C) Starter can be heard attempting to start car, car will not turn over.
D) Car will start at times and fail after a few minutes of idle. (Rough idle, approx 500-600 RPMS, then shut off.)
E) Car will start and no problem will occur until shutting off, wait about 30 minutes, then try to start again and it fails. (Note C)
F) Power loss when accelerating, will not shift correctly. (Only after car starts and driving is possible for a short time)
Parts Checked/ Replaced
LP Fuel Sensor - Replaced
Fuel Filter - Replaced
Cam Follower - Checked/ Ok
Battery - Replaced
Alternator - Checked/ Ok
Starter - Checked/ Ok
Mass Airflow Sensor - Checked/ Ok
Spark Plugs - Replaced
Pressure Relief Valve on HPFP - Replaced
Fuses - Checked/ Ok
FIXED (For the most part....)
Replaced the LP Fuel Pump. Car runs again. Now I'm still getting two codes:
"00135 - Fuel Rail/ System Pressure - Too Low - sporadic 002 - Lower Limit Exceeded"
"00135 - Fuel Rail/ System Pressure - Too Low - sporadic 008 - Implausible Signal"
Any other possible suggestions?
This is what the CarMD report tells me.
http://imgur.com/2n91aJW
