B7 RS4 owner here and have having issue with water ingress. I've drained the drains at the dealer with wire & compressor. In order to replace the aged rubber parts, I require 2 PARSTS to complete the job, yet Dealer's EKTA is only showing one of the two GASKETS as showing (see pic), BOTH the gasket for the BODY/FRAME (which I can't find anywhere for purchase is the one I need) whereas the SUNROOF GASKET (8E0877297) is from numerous outlets. Both gaskets are required to prevent water ingress. Personally, I wouldn't be surprised if they used the same type of part (albeit at a slightly longer length for the BODY gasket) yet it is no where to be found. So I've hit a major bump in the road as that ETKA only shows one of the parts needed of the two. If anyone could help out here I would be very grateful, thank you for your time and have a good day. And yes I search and found nothing both here on AZ and elsewhere, Cheers
