SOLD
Hello,
Don't want to but have to sell my S4. This car has never gone to track or done any 1/4 mile runs and I never intended this car to be more than a sweet daily driver. There's plenty of life and power available in this car.
Quick details:
218,xxx miles I'm the 3rd owner, owned since I think 2009, non smoker, daily driven to work from SF to Millbrae
On a full tank of gas I average about 285 - 310 miles always 91 Octane
Turbos have no to very little whine, still hitting 10psi and pulls great
Only accidents were a hit & run someone hooked a corner too tight and got my driver's side headlight assembly and a truck backed into the truck lid and put a nice size dent next to the license plate.
No clutch slip, shifts very clean.
At moment stock catalytic converter is not letting my smog the car and have sent in Nonoperational registration so price takes a hit.
Things done to the car, mostly stock:
-2.0T Coil conversion
-034 Snub kit
-Goodridge SS brakelines with Zimmerman drilled front rotors/DBA(?) slotted rear rotors
-034 Density Line Control Arm Kit with 034 metal tie end rods recently installed
-APR BI-pipe
-Podi steering wheel pod & boost gauge
-Advanced Automotion 1pc driveshaft
-Clear corner headlight assemblies (can't remember from where)
-1st bank 02 sensors replaced with universals, spacers needed for 2nd set of 02 sensors causing CEL.
-Both EGT boards swapped out, thanks to AZ
-Timing belt done earlier this year all parts OEM from Rector Audi Burlingame
-Lower oil pan seal repaired using high-temp copper gasket seal approx. 2 years ago no leaks
-OEM Oil sensor level changed
-Rear speakers mod
-Replaced front door speakers (purchased from a AZ member, forgot brand and model)
Things to point out:
ABS module needs to be replaced/repaired
Valve cover leaks a little
Driver side airbag throwing an intermittent code
Fuel gauge sensor going bad, still works but on seldom random times the needle will move
Driver side window clips snapped now being held up by zip tie have new set of clips for replacement
A/C needs a recharge
Valve cover seals needs to be replaced
Headliner is starting to peel and hang in the rear
I do have a bunch of miscellaneous parts that will go along with the car, for example 2 BNIB 710N diverter valves, new 034 pancake valve, 1 new extra Matching tire that was not installed yet, couple of O2 sensor spacers, and other bits & pieces.
Title in hand and looking to sell.
