Results 1 to 12 of 12
    Active Member Two Rings Krazydragon780's Avatar
    Sep 05 2016
    2002 Mitsubishi Lancer
    Salt Lake City, Utah
    Humming after engine shutdown.
    So when I got to the store, I shut down the motor, removed the key completely, and sat there and relaxed. Then I noticed that there was this gentle hum coming from between the firewall and the AC. This lasted for a good 5-10 minutes perhaps and then stopped. Does anyone know what this is? Is this normal? Am I crazy? Please chime in.
    Veteran Member Three Rings n8vs3's Avatar
    Jul 10 2016
    I noticed the same thing in my S3 and I think it is normal.
    Aug 08 2016
    Ya mine does it also, pretty sure it's normal.
    Jan 12 2016
    Los Angeles, California
    If I had to guess, its probably a fan to cool something down.
    Very normal, i hear it too
    2016 Monsoon Grey S3 P+ w/ BO, Resonator Delete, AWE Resonated Catted DP, Unibrace UBQ, 034 Rear Sway Bar, 034 Dogbone Insert, 034 Rear Subframe Inserts, 034 P34 Intake, CTS Turbo Inlet, ED Springs, Eurodyne ECU and TCU
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    If I'm not mistaken, its the oil pump still circulating oil to allow the turbo to cool down.
    Sep 05 2016
    Quote Originally Posted by bakedcorn View Post
    I have also heard this somewhere else. Is there any way to confirm this? I think that's a great innovation of Audi if this is truly what the noise is. It certainly deters oil from cooking on the turbo parts, and causing premature wear.
    Jan 15 2010
    Santa Barbara, CA
    Just reminded me of the days when I ran a turbo timer on my B5 S4. :D
    Sep 05 2016
    Quote Originally Posted by forbiddenbeat View Post
    Krazydragon780 likes this
    Veteran Member Four Rings HurrayFive's Avatar
    Jul 21 2013
    Remote
    The, "huuWAANT... huuWAANT... huuWAANT...", noise that you hear several times immediately after shut off is oil recirc through the turbo center cartridge as the remaining oil pressure bleeds off. Once the engine is off there is no oil pressure beyond that.
    The high pitched, "hRRMMMMM", humming that persists a while after is coolant recirc through the turbo center cartridge. Both designed to help keep the turbo bearings in better shape after hard driving. At least that's according to the last tech I asked about it, seems about right.
    They've had similar tech since the last generation EA888, and most new DI turbo engines have similar features now. The old car guy in me still let's the car idle for a couple mins after hard driving so oil can circulate over the bearings. Noise is totally normal though.
    '25 M8 Comp GC Frozen Tanzanite on Ivory/Night Blue - 11.0 @ 126 bone stock
    Jan 12 2016
    Awesome, I glad to know that I'm wrong because this seems like a great feature to help prevent some kinds of wear which may have been more prevelent in older turbocharged engines.
    Dec 21 2015
    Melhbach, Germany
    ^ Old cars required you to install a turbo timer to ensure your turbo cooled down properly. Now the manufactures caught up with COMMON sense on how to keep the turbos from melting.
    2016 Audi S3 (CTS Intake, JB1, dogbone, AWE track catback..)
    2002 Trans Am WS6 (Sold)
    2012 SRT8 (Sold)
    1997 Viper GTS (Sold)
    2006 Z06 (Sold)
    2004 Viper SRT10 (Sold)
    2010 GT500 (Sold)
    Oct 26 2016
    Sacramento, CA
    Yeah, my A3 hums for a bit, but also have some regular electronic pulse sound coming from the engine. My wife said it sounds like a bomb timer and that my car is just counting down the days where it will explode and kill us all. Very weird car...when it's off.
