I haven't posted much here, but I have been reading, almost weekly it seems, finding great information on how to keep my b5a4 running. It has, unfortunately, become more work than its worth, and to pay someone else to do it would cost more than the car is worth literally.
I sit here, having had my heater core literally pop and fill my cab with the acrid fumes of coolant steam. Like, I heard pop, then couldnt see...
I have bypassed the core, but I dont have 10 hours to figure out where all the nuts, bolts, etc... are that I have to remove/replace to pull the core to replace it. She was a basket case when I bought her, and she's leaving me a basket case as well. I dont know when she's leaving.. but I'm done, next major repair and its over. If she limps along till next summer, good, if not, good riddance.
Of the things I've had to do in the last year..
Valve cover gasket
replace exhaust
o2 sensors
coolant overflow tank
bypass the heater core
evap canister
evap canister purge valve/pump
replace all of my pcv system
teh gasket between the intake and the block
temp sensor, 2x
speed sensor on the driver side front wheel hub
vacuum line repair
Things that still dont work, and I'm not fixing them
three windows.. think it may be motor or switch on one, its the regulators on the rear
cruise control
heat (now)
auto dimming rearview is dark all the time
side view mirror is dark/delaminating
still have an 02 sensor or two that could use replacement
have a squeak in my suspension that is probably bad
and
Timing belt is due in like 17k miles..
This will probably not be my last german car, it probably wont be my last VAG vehicle in all reality... but for now, I bid yall adieu.
This forum is great.. I like it as much as I did when I was on tdiclub for my tdi.. Best wishes and thanks for all the fish.
