Results 1 to 3 of 3
    Senior Member Two Rings BuffysRS4's Avatar
    Jun 12 2004
    Audi A4 1.8T, Audi Q7 3.6 Prem
    Markham, ON - Eastvale, CA
    Question 5th gear & reverse gear lock
    Anyone have experience with this device on an AEB Manual 1999.5 B5 A4?
    I was having issues with a sloppy shift pattern, so I rebuilt my shift assembly with a new ball housing and set it back up per the Bentley Manual. Now I can't get into Reverse. I picked the brain of the mechanic at the Audi dealership and he has never had to work on such an issue (20 years working on Audis).
    I have the metal shifter housing assembly not the plastic one piece of the later model B5s. I have adjusted the ball housing to pivot the maximum adjustment in order to try to get the reverse gear to engage to no effect. While going through the Bentley I read about the gear lock and was hoping someone that might have some experience with it could chime in.
    "Speed kils, drive better"
    2007 Audi Q7 3.6 Premium
    2004 Volvo XC90 T6 AWD (TRADED POS)
    1999.5 Audi A4 1.8TQM
    1996 Mitsubishi Montero LS
    1993 Geo Storm SiR (RIP)
    1992 Mazda 323 (RIP)
    Dec 05 2007
    With the car off, see if you have any issue getting in and out of any gear. Of no, then I would suspect either your throw out bearing or pilot bearing being the issue. Taking a guess here, but had a similar issue prior. Not exact, but similar.
    My pilot bearing was beyond time for a replacement. Did that and TO bearing same time. Fixed it, but tranny was already shot by then and swapped that out after I lost 2nd or 3rd gear. Prior to that, one of those was already gone and drove without that gear for a while (bad tranny internals since ownership. years before it took its plunge to the pointvod no return).
    I did a short shift kit swap so would imagine it would be the same. Lock it into revers when doing the bolts for the linkages which means you can get 1-5 and r make sure to lock tight it on bolts that you don't want coming loose as you have to do it again
