    Junior Member Two Rings
    Jan 04 2012
    dfw
    1997 A4 - Suspension (Lower and UpperArms) Kits Reasonable Quality and Price Options
    Hi,
    I am looking for a reasonable ratio quality - price Suspension (Lower and UpperArms) Kits.
    I see the genuine kit is 1.5k USD, while the aftermarket sells for 150 to 250 USD, but I cannot really get the reviews on how well the perform after some time. I read some fail very quickly.
    I am not looking into sports kits, but I want a reasonable kit, so I do not need to change parts after few months - that seem to be the case for some kits.
    What do you use? How did they perform?
    Veteran Member Three Rings LA4's Avatar
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    I've been looking into redoing mine again recently. Best options seem to be-
    -FCP Euro - ~$200-250
    -Meyle HD - ~$400-450
    -034 Density Line- ~$400
    Don't think I've ever seen a kit go as cheap as $150, but I'd be wary of it. Personally I am already a bit iffy about the FCP Euro kit at $200. It comes with a lifetime warranty, but you still need to take into account the time it takes to replace the part, the inconvenience of having a vehicle down, plus you probably want an alignment after fucking with your suspension ($100+).
    1998.5 A4 Quattro 1.8TQM AEB
    Stage 1 GIAC, 710N DV, ECS Snub Mount, ECS SS Brake Lines, A8 Rotors, Bilstein Sports/H&R Springs
    Dec 10 2013
    Borden, Ontario, Canada
    MEYLE HD from FCP highly recommended. Very good looking piece of kit. I cheaped out and went with FCP kit on my S4. Regret it
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Feb 27 2011
    Winnipeg
    I've used FCP arms in all of my current and previous Audis, out of the cheap control arms I've never had to change one yet, URO parts, MOOG, Mevotech, MTC all have had low mileage failures, always the balljoint getting sloppy. If I ever have to get a whole set of arms again I'll probably go with the Meyle HD set. The plus side of running shitty control arms is that the pinchbolt never has time to seize up again
    Established Member Two Rings czum09's Avatar
    Nov 02 2010
    1999 Audi A4
    Cedar Rapids, Iowa
    I have FCP. No complaints at all. Regardless of the kit, make sure you torque the bolts with load on the suspension!
