Results 1 to 10 of 10
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    Cool 1998 Audi A4: Hibiscus 12v VR6 Turbo, HTA3582r, E85, 500+ WHP
    Looking at possibly selling my B5 to get into a P-car.
    Price: $15,999 SOLD!
    SOLD!
    Some specs on the car:
    It's a 1998 A4 with special order hibiscus pearl paint. I purchased the car nearly 10 years ago when it had an APR stage III system on it. From there it went through several different turbo/engine configurations until I got the crazy thought in my head to pull off the VR6 swap. The chassis currently has 128,000 and the VR6 swap has about 22,000 on it. It's currently tuned on E85 to about 25lbs of boost on the HTA35r which puts it somewhere in the vicinity of 500 whp. Last time I had it dyno'd it made 488 awhp/460awtq on a Mustang dyno with less timing than where it sits currently. Turning up the boost should end up somewhere around 600 awhp with the possibility to swap out the HTA3582r for a 6466 or larger turbo for more power.
    Onto the mods:
    Engine:
    -2.8l 12v VR6
    -C2 8.5:1 Head spacer
    -ARP rod bolts
    -ARP head studs
    -034 high rate valve springs
    -034 titanium retainers
    -Techtonics 268* cams
    -Fresh valve job
    -All new timing chain components
    -034 billet motorsport motor mounts
    -custom steel VR6 motor mount bracket to utilize stock motor mount location
    -034 Longitudinal VR6 Starter
    -OEM VR6 Phaeton oil pan
    -Custom silicone coolant lines
    -Setrab 25 Row oil cooler
    Forced induction:
    -Forced Performance Garrett HTA3582r .82 a/r Turbo
    -3" 304 stainless steel downpipe (v*banded)
    -3" 304 stainless steel exhaust with HKS muffler (v*banded)
    -034 12v VR6 Longitudinal intake manifold
    -034 12v VR6 Exhaust manifold
    -Precision 600hp intercooler
    -Synapse blow off valve
    -custom 2.5" intercooler piping
    -4" aluminum intake
    -4" AEM Dryflow air filter
    Drivetrain:
    -6 speed 01E transmission
    -Spec Stage 5 Clutch with super clamp option
    -034 Longitudinal VR6 swap flywheel
    -OEM VR6>01E adapter plate
    -AWE Drivetrain stabilizer
    -034 track density transmission mounts
    -Stern urethene rear diff carrier bushings
    -Stern rear diff mount power ring
    Electronics:
    -034 IIC Standalone Engine Management
    -Custom flying lead wiring harness integrated into stock wiring harness (no lights on the dash)
    -Phormula KS4 knock analyser
    -AEM Uego Wideband gauge
    -034 6 cyl waste spark coil pack
    -Custom MSD spark plug wires
    -Dual 10" front mounted radiator fans
    Fueling:
    -Custom billet -6an 12v VR6 fuel rail
    -Aeromotive fuel pressure regulator
    -Bosch 044 inline fuel pump
    -Walbro 450lph intank fuel pump
    -Fuelab -6am glass element fuel filter
    Interior:
    -S4 silver alcantara seats
    -S4 headliner conversion
    -S4 door sills
    -black alcantara shift boot
    -double din center console
    -gauged upgraded dials
    -Joying Android headunit w/bluetooth/nav
    -MB quart speakers all around
    Exterior:
    * -S4 side skirts
    * -S4 rear bumper
    * -Reiger RS4 front bumper with custom dzus fastener brackets
    * -Reiger rear window spoiler
    * -Valeo E-code headlights
    * -OEM RS4 front grill
    * -OEM RS4 brushed aluminum mirrors
    *- Aerocatch hood pins
    Wheels/brakes:
    * -18" Volk LE37
    * -Cayenne 18z front calipers
    * -Stainless steel brake line all around
    * -ML55 front rotors
    * -B5 S4 rear brakes
    * -EBC yellow stuff pads all around
    * -Michelin Pilot Super Sports tires
    Suspension:
    * -Vogtland coilovers
    * -Fresh meyle front control arms with less than 20,000 miles
    * -CPP rear toe links
    * -Hotchkis 22mm rear sway bar with welded in rear subframe brackets
    * -Lltek front strut brace
    Exterior condition: 8/10
    1) The car is really in immaculate shape. Its been in a climate controlled garage its whole life and has barely seen rain except for in the past year when I've been DD'ing it here in Houston. Not a single door ding or major scratch on the car anywhere and I detail on the side so the paint has no swirls either.
    2) No accident history.
    3) The only cosmetic defects is some rust that began to form on the driver side door sill from water getting trapped in the plastic door sill cover and a small section of rust on the drivers interior door. Neither of these are visible from outside of the car.
    4) Typical light wear such as small rock chips on the front bumper and side skirts.
    5) The only dings that are present are small reverse dings on the hood where the engine mounts broke back in 2013 allowing the engine to contact the hood (they're barely noticeable).
    Interior condition: 7/10
    1)Drivers seat has some wear on the bolsters
    2)Headliner is beginning to sag in the back
    Items that the new owner might want to address:
    1) I've been running the car with just dumping the crankcase vapors to atmosphere. It doesn't really bother me but the new owner might want a catch can to reduce the vapor load.
    2) The oil cooler necessitated removing the windshield reservoir so there is currently no windshield washing function. A custom tank will need to be fabricated for the windshield reservoir to add this function back.
    3) The AC compressor is currently installed in the car but new lines need to be fabricated. Otherwise I have all the components to get AC back in the car.
    Tunes:
    Nearly all of the miles on the swap have been on E85 but I periodically run a tank of 93 to flush any deposits that form. The car will come with both an E85 tune and a 93 octane tune (you'll need a laptop to switch the tunes) and you'll need to turn down the boost on the 93 octane tune.
    Oct 30 2006
    B8 A4 Avant 6spd
    I'm sure someone is going to ask this at one point but, why are you selling if I may ask?
    -18 718 GTS
    Feb 13 2007
    98 A4
    Chicago
    Quote Originally Posted by Militant-Grunt View Post
    It's a bit of a combination of wanting something new (I've owned it for 10 years so I've lost a little interest in it) and realizing that if I keep this car any longer I'm going to put a bunch more money into it. If I keep it I'd want to put a bigger turbo on it which easily cascades into re-doing all the other components. I'm sure you know how slippery of a slope this can become....
    Ideally, I'd sell it and put the proceeds from the sale into something that's fairly quick in stock form. Specifically I've been looking at 996 TT's.
    Worst comes to worst I'd be open to parting out the car but I feel as though there is more value in a complete, running, and reliable VR6 swap B5 than a parted out one.
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    You should post this on the Exclusive Audi Clubs of Houston (EACH), Texas Audi Group, & Texas Audi Owners on facebook if you haven't. I believe you did a cruise with us a few months ago and we're doing it again Nov 12th and Coffee and Cars on Nov 5th.
    Jul 05 2015
    Open to any trades?
    Jul 05 2015
    Can I get a phone number to contact you by?
    Feb 13 2007
    98 A4
    Chicago
    Quote Originally Posted by sliceandkick View Post
    Open to any trades?
    Possibly but I would be hard pressed to get into another Audi that is slower than mine. I would consider touaregs, cayenne or q7's. Just got two new puppies so i could use the extra room....😊
    Veteran Member Three Rings Mr.Jetta's Avatar
    Nov 01 2008
    Illinois
    "-3" 304 stainless steel exhaust with HKS muffler (v*banded)"
    BRAAAAAAAAAAAP!
    I can attest to the cleanliness and sheer power of this car as I have seen and driven it. Absolutely phenomenal vehicle. And the sound alone will make panties/boxer-briefs drop. (in case you're into either/or)
    Sad to see this car go if that happens. Miss you J.L. <3
    B9 SQ5 3.0T AGM
    MKV .:R32 DBP
    '16 Volvo V60 Polestar T6 BSM
    PREV: MK1 TT Coupe 3.2 (6M/T), B6 S4 Avant, 8V A3Q
    Feb 13 2007
    98 A4
    Chicago
    Quote Originally Posted by Mr.Jetta View Post
    BRAAAAAAAAAAAP!
    Thanks Dev, it will truly be sad to see it go.
    There's been a lot of interest but no one has came up with the cash yet.
    Veteran Member Four Rings NYEuroTuner's Avatar
    Oct 24 2008
    "Silvaro" B5 S4, 2013 B8 S4, 2018 RS3
    Coming home to us :)
    -- George
    SEMPER FI
    Build Thread--------------->My VR6 Journey<-Click it, Click it good.
    IABEDINDUSTRIES
