Hi All,
I picked up the JL 500 watt mono sub amp, JL 12TW3 with JL factory thin enclosure., amp wiring kit, line converter and etc...
I was a car audio installer way back in my hs/college years. I am not completely a noob but I am definitely under an inch of rust and behind the times.
I started the process tonight. I secured the power/fuse and ground. I have figured out to get the remote wire lead from the accessory outlet in the trunk. I am left figuring out where to pull the lead for my line level converter. I have read a dozen posts and I have read varying approaches. So far, the best I have seen indicate pulling the lead from output on the bose amp. My bose amp is deep in the compartment on the drivers side and not easy to get too. Before I go any further, I wanted to see if anyone was successful tapping the lines going into the factory sub. My sub has a black, solid gray and gray/purple if I recall correctly from looking at the factory plug feeding the subwafer.
BTW, this sub is so small and thin that you could mount is pretty much anywhere and keep our trunk space at near full capacity. I do plan to dye the white JL logo black to make the box disappear. I highly recommend this sub/box combo for those that want to save space and add bass.
Thanks in advance.
