Results 1 to 6 of 6
    Sep 02 2008
    Boonies VA
    Vacuum Pump Bolt - Part Number?
    I ordered a new vacuum pump today as mine is leaking, was feeling around to get an idea of where all the mounting bolts are and while the top 2 are easy enough to spot. The bottom one is apparently missing, kind of pissing me off (long story) so now I need to also order a new bolt.
    I would just try to edit the order of the pump, but it has already shipped.
    White Wagon
    Veteran Member Three Rings deusilan's Avatar
    Aug 17 2012
    '89 E30 325i; 2005.5 2.0TQ 6-spd
    Stinky Island, NY
    You can take one off and see what you have. If you have a threadchecker, you can order a screw from McMaster-Carr.
    Currently: 2005.5 A4 2.0 (Red)TQ 6-spd, WORK IN PROGRESS 2011 Police Interceptor
    Previously: E30 325i, donated for track purposes
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    It's an M6 diameter and 22mm long. I have no idea about the thread pitch but it's probably 1.0mm. Part number is N10196303
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Feb 15 2016
    Cambridge,Ontario
    I would NOT get the same bolt . that thing is a pain in the ass .. just get a standard yellow zinc bolt with the above specs, don't forget you are holding a grounding bracket. Don't over torque as you can strip out the timing cover easily. Mine is hanging on by lock tight and a couple of threads.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Sep 02 2008
    Boonies VA
    Thanks all, new pump should be here today. The odd thing is I have not noticed any more oil leaking since wiping it off, half wonder if when the coolant flange was replaced some leaked out and was not cleaned then (I had a shop change the flange, was not prepared to deal with that headache). Might keep an eye on it for the next couple days, although I have no plans to drive anywhere, and if it is not leaking return the new pump, if it is leaking will swap it out.
    White Wagon
    Veteran Member Three Rings wding2000's Avatar
    Jul 04 2015
    08 A4 Quattro Avant; 16 Golf MK7
    Quote Originally Posted by Denio24 View Post
    DO not think this is the bolt. The bolt has the same M6 diameter and pitch, but has a much larger cap (for holding grounding wire bracket). Sorry, I do not know PN. It is most difficult to get out - after breaking it loose, b/c bracket, could not get it out hand, had to wrench it out in tight space.
    08 a4 2.0t quattro avant | eng bwt 200hp | tip 6-spd zf 6hp19a | akebono ceramic | andros 18x8 et35 cb72.2 72-57 centric rings | pirelli p0as+ 235/40r18 | hu xtrons px5 mtce_gs_3.40 android 8 | rev d dv
