Results 1 to 11 of 11
    Apr 01 2015
    2004 Audi A4 B6 3.0 Quattro, 2015 GMC Terrain, Infiniti G35 Coupe
    United States
    Had Cranking Issue Just Realize a ton of water in my battery compartment
    My car is used primarily for winter, so it's not my DD. As I was getting ready to make sure everything was good for this coming winter, I started getting cranking/starting issues. Replaced the battery about two days ago due to some hard starting and when it was tested the CCA was at 470. I thought my problems were solved, but it still took one or two starts to get going. Today, after a long downpour I went to start the car and it was running terrible, so I took my other car and decided to troubleshoot the car today.
    I got home and the car started, sputtered, and was running like crap. It then started misfiring, CEL flashed on me, and the car just died after a few times. I thought I was having some alternator problems, so I was trying to measure the battery voltages. I pulled the battery cover up and I noticed there was just a ton of water stuck in there, however, it doesn't look like it got high enough to get in the ECU. I also didn't noticed anything wet inside the car either, I took the battery out and cleared out the drain hole. I then took the cover off the ECU itself and nothing looked wet, brown, or damaged in anyway. But, I know electrical issues can go unseen.
    All the lights come on and the car cranks, but it just doesn't start. I have the CEL, ESP, EPC, and battery light all on the console.
    I have the MAF disconnected, so that error I'm not worried about. I also got the PRNDS light error the other day, so I'm not too concerned about the F125 switch now either. The crank sensor stands out to me as well, since it says implausible signal. P1602 error code also stands out, because I do think I might be having alternator problems, but it also says it can be a weak battery or disconnected cables. I did have the cables disconnected and replaced he battery as well.
    Is it possible my ECU might be jacked up though? I mean it seems to be communicating without any issue.
    I ran VCDS and here are all the codes I got and there is a lot!
    Friday,28,October,2016,19:49:03:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    Data version: 20130910
    VIN: WAULT68E84A060838 License Plate:
    Mileage: 314000km-195110mi Repair Order:
    Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: WAULT68E84A060838 Mileage: 314000km/195110miles
    Address 01: Engine Labels: 06C-909-559-ASN.lbl
    Part No SW: 8E0 909 559 L HW: 8E0 909 059
    Component: 3.0L V6/5V G 0010
    Coding: 0016751
    Shop #: WSC 63351 000 00000
    VCID: 3E73D8736A826EEEA6F-5000
    16 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - - MIL ON
    16690 - Cylinder 6
    P0306 - 008 - Misfire Detected - Intermittent
    18032 - MIL Request Signal Active (Check TCM for errors too!)
    P1624 - 008 -
    17833 - EVAP Purge Valve (N80)
    P1425 - 002 - Short to Ground - Intermittent
    17880 - EVAP Leak Detection Pump
    P1472 - 002 - Short to Ground - Intermittent
    17843 - Secondary Air Pump Relay (J299)
    P1435 - 002 - Short to Ground - Intermittent
    17829 - Secondary Air Injection Solenoid Valve (N112)
    P1421 - 002 - Short to Ground - Intermittent
    16486 - Mass Air Flow Sensor (G70)
    P0102 - 002 - Signal too Low - Intermittent
    16686 - Cylinder 2
    P0302 - 008 - Misfire Detected - Intermittent
    17537 - Fuel Trim; Bank 2 (Mult)
    P1129 - 002 - System too Rich - Intermittent
    18010 - Power Supply Terminal 30
    P1602 - 002 - Voltage too Low - Intermittent
    16685 - Cylinder 1
    P0301 - 001 - Misfire Detected
    16688 - Cylinder 4
    P0304 - 001 - Misfire Detected
    16689 - Cylinder 5
    P0305 - 001 - Misfire Detected
    16497 - Intake Air Temp. Sensor (G42)
    P0113 - 002 - Signal too High
    16705 - Engine Speed Sensor (G28)
    P0321 - 008 - Implausible Signal
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 8E0 927 156 Q
    Component: AG5 01V 3.0l5V USA 1214
    Coding: 0001002
    VCID: 3C77D27B7C9E7CFE88B-5072
    4 Faults Found:
    17095 - Transmission Fluid Temp Sensor (G93)
    P0711 - 003 - Implausible Signal - Intermittent
    18161 - Tiptronic Switch (F189)
    P1753 - 003 - Implausible Signal - Intermittent
    17090 - Transmission Range Sensor (F125)
    P0706 - 003 - Implausible Signal - Intermittent - MIL ON
    18265 - Load Signal
    P1857 - 003 - Error Message from ECU - Intermittent
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 3429
    Coding: 04497
    Shop #: WSC 06435
    VCID: 26431013C212D62ECEF-5072
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1219
    Coding: 00000
    Shop #: WSC 63351
    VCID: 63C54907F1A06306E91-5000
    No fault code found.
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul USA 0517
    Coding: 01013
    Shop #: WSC 63351
    VCID: 3561C75F0FB4ADB6775-4A9C
    1 Fault Found:
    01493 - Bulb for Blinkers; Front Left (M5)
    57-00 - Electric Circuit Failure
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 C
    Component: Airbag 8.4EP 3001
    Coding: 0010607
    VCID: 377DCD5745B85FA6659-5072
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0308
    Coding: 02041
    Shop #: WSC 63351
    VCID: 3E73D8733A826EEEA6F-4A3A
    1 Fault Found:
    01304 - Radio
    49-00 - No Communications
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 L
    Component: KOMBI+WEGFAHRS. RB4 D37
    Coding: 03400
    Shop #: WSC 08219
    VCID: 326BFC43FEDABA8E527-50E6
    WAULT68E84A060838 AUZ6Z0C0235229
    1 Fault Found:
    01304 - Radio
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1411
    Coding: 11788
    Shop #: WSC 63351
    VCID: 72EB3C433E5AFA8E927-4A3A
    Subsystem 1 - Part No: 8E1959801G
    Component: Tőrsteuer.FS BRM 0706
    Subsystem 2 - Part No: 8E1959802E
    Component: Tőrsteuer.BF BRM 0003
    Subsystem 3 - Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0003
    Subsystem 4 - Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0003
    11 Faults Found:
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
    35-00 - -
    01366 - Opened Due to Crash Signal
    36-10 - Open Circuit - Intermittent
    00955 - Key 1
    35-10 - - - Intermittent
    01705 - Selection Switch for Mirror-Adjust (E48)
    27-10 - Implausible Signal - Intermittent
    00932 - Electric Window Motor; Drivers Side (V147)
    62-10 - No or Incorrect Adjustment - Intermittent
    00915 - Window Regulator Switch; Rear Right; Driver (E55)
    00912 - Window Regulator Switch; Front Left (E40)
    00913 - Window Regulator Switch; Front Right Driver (E81)
    01331 - Door Control Module; Driver Side (J386)
    53-10 - Supply Voltage Too Low - Intermittent
    End ---------------------------------------------------------------------
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    That's a lot of codes, probably from your battery dying or something, so clear them, crank again, and post what shows up.
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Holy crap bat man long post. If the battery compartment was full I'm sure your Ecu got wet open Ecu box dry every thing out clean terminals if necessary clear codes see what comes up
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Apr 01 2015
    United States
    Well, I cleared the codes and the only one that came back was the 16497 - Intake Air Temp. Sensor (G42)
    Apr 01 2015
    United States
    Opened up the ECU box and took out the ECU and the other metal box under it and it was bone dry. I tested my crank sensor and it tested correctly according to AllData and I also tested my fuel pump relay, which clicked and had voltage across the terminals. The relays in the ECU box still looked clean and newish, I'm looking at 219 now to try and test it as well.
    Apr 01 2015
    United States
    Well, I'm about 85% sure I'm having either a fuel pump problem or some kind of fuel delivery issue. I only had a few minutes to troubleshoot today, since I had to take my stepson trick or treating. But, I sprayed a little starting fluid after the MAF and it didn't start, but it did seem to "try". I disconnected the fuel line, attached it to a hose, and then pointed it to a catch can and nothing was really coming out when I cranked the engine. I then hooked the lines back up and disconnected them again, but there was a little bit of pressure without much fuel coming out. I'm going to still look at spark and need to test power going back to the fuel pump, before I conclude my diagnosis.
    I have a walbro 255 fuel pump clone around my house and I might swap that in if my pump is indeed bad.
    Apr 01 2015
    United States
    Well, I figured out my problem or at least I know what caused my car to stop working. Does this damn car have another fuel pump in it or something??? LOL. The passenger side was completely dry, but I had at least 3 gallons left and I know my gauge works fine. I pulled out my fuel pump and it works fine, so I added about three more gallons to the tank (fuel gauge raised accordingly also) and the car started up fine.
    Is there another pump that feeds fuel from the driver to passenger side of the fuel tank? I saw the other access panel, but figured it's like my G35 and for another fuel sending unit....oh those Germans.
    I have a Quattro also.
    Aug 15 2016
    Western Canada
    Fuel suction jet pump or the associated hoses are fuct. it's a passive venturi type thing that relies on vacuum from the return fuel, so any leaks on the hoses across the sides render it kaput.
    2 in this picture
    Apr 01 2015
    United States
    Interesting, I'll have to open the other access panel tomorrow. I didn't really see any of those other hoses connected to the basket or the actual fuel pump itself. I'll have to see if they came lose or broke off somehow.
    Jun 26 2015
    Tampa, FL
    If you drive it as is, be aware that it will "run out" of fuel in the same manner while you're driving. In other words, don't let your gas gauge go too far past halfway.
    Apr 01 2015
    United States
    Yea, I realize that now, lol. I been troubleshooting this thing for almost a week so far that started with some weird electrical issues. Latest problem occurred in my driveway, I have another car so that helps a lot when maintaining them. So, far I've paid nothing and almost towed it to a mechanic. They probably would have thrown a fuel pump in and called it a day...glad I took some time to do this.
