Results 1 to 4 of 4
    Senior Member Two Rings jwallace0988's Avatar
    May 16 2016
    None
    Rochester, NY
    Just tried out Carista
    So I have had the BT adapter sitting around for a bit and found myself with some time today. Car came up with 3 faults, TPMS was a no brainer with the weather changes up north here in Ny.
    Should I be concerned with code 01324 for Control Module for All Wheel Drive
    What do you guys think? Is it normal for it not to connect to a lot of these systems?
    ECU info obtained with Carista 310199 for iOS:
    VIN: WAUBGAFL8DA096954
    CAN network gateway
    Part #: 8R0907468H
    Coding: 80C303FF00 (hex)
    Component: GW-BEM 4CAN-M
    [No fault codes]
    Engine
    Part #: 8K5907551E
    Coding: 0A250034052608060000 (hex)
    Component: 3.0l V6 TFSI
    [No fault codes]
    Transmission
    Part #: 8K2927156M
    Coding: 000001 (hex)
    Component: 0B5 30TFSINAR
    [No fault codes]
    ABS
    Part #: 8K0907379CK
    Coding: 291D1A (hex)
    Component: ESP8 quattro
    Fault codes:
    01324 Control Module for All Wheel Drive (J492)
    02214 Tire Pressure Warning
    Parking brake
    Part #: 8K0907801L
    Coding: [none]
    Component: EPB-4
    [No fault codes]
    Power steering
    Part #: 8K0909144F
    Coding: 100000010001 (hex)
    Component: RCEPS
    [No fault codes]
    Steering wheel
    Part #: 8R0953568S
    Coding: 000036 (hex)
    Component: Lenks.Modul
    [No fault codes]
    Airbags
    Part #: 8K0959655P
    Coding: 303844354730303030304A55304C384B3053 (hex)
    Component: AirbagVW-AU10
    [No fault codes]
    Instrument cluster
    Part #: 8K0920982L
    Coding: 83BF09008301D705020000 (hex)
    Component: KOMBIINSTR.
    [No fault codes]
    Radio
    Part #: 4G0035082G
    Coding: 020007010000000001 (hex)
    Component: Radio U SIRIU
    [No fault codes]
    Sound system
    Part #: 8T1035223A
    Coding: [none]
    Component: DSP Prem
    [No fault codes]
    Infotainment system
    Part #: 8R1035746D
    Coding: 110200000206A1EF45028B4E00000403140000000000000000 (hex)
    Component: H-BNT-NA
    [No fault codes]
    Heater & air conditioning
    Part #: 8K1820043T
    Coding: 6600228000 (hex)
    Component: KLIMA 3 ZONEN
    [No fault codes]
    Central electronics
    Part #: 8K0907063DH
    Coding: 26000091813CAFE0210048C300003D0D4F9CD308A209022100 0008004000030100000030000000 (hex)
    Component: BCM1 1.0
    [No fault codes]
    Body/convenience system
    Part #: 8K0907064GM
    Coding: 01060E3A00FA400580B0013200000000 (hex)
    Component: BCM2 2.0
    [No fault codes]
    Driver's door
    Part #: 8T0959793P
    Coding: 011C13204E00410001 (hex)
    Component: TSG FA
    [No fault codes]
    Front passenger's door
    Part #: 8T0959792P
    Component: TSG BF
    [No fault codes]
    Rear left door
    Part #: 8T0959795Q
    Coding: 010C13204000210001 (hex)
    Component: TSG HL
    [No fault codes]
    Rear right door
    Part #: 8T0959795Q
    Component: TSG HR
    [No fault codes]
    Driver's seat
    Part #: 8K0959760D
    Coding: 00581B00000000000000 (hex)
    Component: MEM-FS
    Fault codes:
    03332 Motor for Adjustment Seat
    Ignition authorization
    Part #: 8K0907064GM
    Coding: 0D814000000000000000 (hex)
    Component: BCM2 2.0
    [No fault codes]
    Battery charging
    Part #: 8K0907163B
    Coding: [none]
    Component: 4 Wheel Drive
    [No fault codes]
    Back-up camera
    Part #: 8T0907441C
    Coding: 1000006 (decimal)
    Component: J772__Rearview
    [No fault codes]
    Additional functions
    [failed to connect]
    Operations
    [failed to connect]
    Back-up camera
    [failed to connect]
    Last edited by jwallace0988; 10-29-2016 at 09:24 AM. Reason: Removed [Failed to connect items]
    13' S4 - Ice Silver (DSG, B&O, Carbon Inlays, Black/Magma Leather, Sports Diff) - EPL Stg. 1 ECU w/ DSG tune, Roc Euro Intake, DeAutoKey Full LED interior(white), Red (Front floor), LED Exterior lighting (Turn/Reverse). Eurocode poly mounts, Soundakor DELETE!, Xpipe mod, Carista!
    Past: 12' GTI Autobahn, APR Stage 1, CM FX350 w/ flywheel, Magnaflow CB exhaust :: 06' Scion tC: Full Bolt-ons to turbo build at approx. 300 WHP/TQ on 8-10 psi, Konig After-burners, RL Coils, poly mounts etc.
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    I don't have an answer to your question, but I feel like if you mentioned fault codes somewhere in the title you might attract people who know about those kind of things versus people who want to talk about Carista. Good luck!
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    May 16 2016
    None
    Rochester, NY
    Quote Originally Posted by LordMagnet View Post
    Fault code or anything! Do you have it? I do like it and think it's cool you can use it without getting too much involved (like it's simple) I do however feel that the MK6 GTI was a lot more customizable than the same MY as my S4, so I'm slightly disappointed in the actual Audi mmi... oh well!
    Mar 21 2015
    ^ You proved his point lol.
