Results 1 to 10 of 10
Thread: PCV Question
    Senior Member Two Rings Bonz099's Avatar
    Jun 30 2015
    Rockville, MD
    PCV Question
    So I was looking for a new PCV valve. Is the consensus that that it "HAS TO BE OEM" the only way to go?
    ECS seems to have a bunch of different brands.
    https://www.ecstuning.com/Audi-B6_S4...iteSearch/PCV/
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    I've heard similar things... I grabbed an OEM one from ECS a while ago, haven't had time to install it. Something else that my mechanic mentioned is rebuild kits to replace the diaphragm inside of them. I haven't seen them, but I've known my mechanic for 20+ years and he's never steered me in the wrong direction.
    Anyone else seen a rebuild kit? I figure with 2 OEM you can flip flop by rebuilding the one out of service.
    Jul 15 2015
    Rochester NY
    Good timing - I just bought a Meyle brand to replace the OEM, just because that's what the vendor had. I cleaned out the old one and huffed and puffed in both and couldn't tell any difference. I don't think the old one is broken - I just bought the new one "in case". Judging by what it looks like inside, I could probably swap the diaphragm between the two
    Jul 05 2016
    Ontario, Canada
    The issue is definitely that they get gummed up... I'm wondering if a catch can helps much with this...
    Oct 02 2005
    The Moon
    ALL NON AUDI PCV ARE POOP.
    Honestly they all start quacking after no time.
    It's really one of those parts where you want the real thing.
    Apr 26 2016
    Kia Sportage V6 - Wifes car
    Metuchen New Jersey
    Quote Originally Posted by p3u View Post
    i had an aftermarket pvc on my S, and it started screaming like an air raid siren after 400 miles..... definatly not worth the 35.00 savings..
    Sent from the S that used to tap
    My S used to have a tap, a valve slap... now it makes no noise at all! RIP
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    anecdotes abound, but I am over 14k miles on an aftermarket one, no issues yet -knocks on wood-
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Apr 26 2016
    Metuchen New Jersey
    well you cant exactly go by the luck ive been having... just saying whats happened to me
    Oct 29 2015
    Richmond VA
    I got one month out of aftermarket before the duck of death noises started
    2013 TT RS (Sold)
    2013 Allroad (Sold)
    2017 S3 (sold)
    2006 25 Quattro S4 #50 (dead)
    Senior Member Two Rings alcatranz518's Avatar
    Jun 10 2014
    Stoneville, NC
    Audi is the by far the one I have seen that, without question is not worth ANY savings to buy the aftermarket alternative for factory maintenance/ replacement parts. If it's they are so well engineered/ built that the slightest deviation in aftermarket part mfg causes improper function or that the aftermarket for our cars is just plain crap and worse then for others, that is subject for debate.
    As much as one would think the explanation is just the crap aftermarket parts for ours, I personally believe its the latter. Seeing as many of the aftermarket parts are from Germany, but also studying and understanding the design intent, tolerancing, and quality control involved in the Audi/ VAG brands; I think it just is a factor of the tighter tolerancing and less accountability for deviation. I do believe some of the aftermarket is higher quality, just our brand isn't engineered to deviate far from original design specs. (But it definitely doesn't help to have pure garbage aftermarket in some cases though.)
