Results 1 to 11 of 11
    Active Member Two Rings Krazydragon780's Avatar
    Sep 05 2016
    2002 Mitsubishi Lancer
    Salt Lake City, Utah
    Anti-Dazzle Mirror
    So my car just came with a manual mirror, and I miss the old one that used to be in my BMW. Per the FSM, there is an anti-dazzle mirror that is available. Where can we get the mirror?
    Established Member Two Rings S3owner's Avatar
    Jun 16 2016
    Ontario
    I thought thats a standard feature in S3!
    Missano Red II S3 Quattro 2.0T - H&R Sport Springs - Spacers 10mm/17.5mm - Sound Enhancing Resonator Delete - USmillWorks tow hook bracket - Pinalloy carbon key fob cover - Carbon Fiber mirror caps - matte black diffuser
    Instagram
    Veteran Member Four Rings BranCKY3's Avatar
    Mar 08 2005
    Greenville, SC
    Mine is auto dimming. I thought that was standard?
    2016 Audi S3
    Sep 05 2016
    I have the A3.
    Sep 05 2016
    Since I have the A3, can I simply purchase the mirror for the S3 and install it Plug and Play, or will there be more to it?
    Veteran Member Four Rings HBird's Avatar
    Jul 18 2015
    2019 Ranger, 2023 4Runner
    Snohomish, WA
    Quote Originally Posted by Krazydragon780 View Post
    I'm sure it's plug and play, but you'd have to figure out where the wiring is for the auto dimming element and code it in. Since it reads off of the sensor in the rearview mirror (assuming it does), there might be more to it though.
    Senior Member Two Rings MkUrMark's Avatar
    Aug 09 2015
    Southern Cali
    I have a 16 prestige s3 and my mirrors don't fold
    2016 S3
    12' Golf R:. Stg 1+sold
    10' Gti sold
    06 A4 sold
    May 02 2016
    Ft Lauderdale FL
    I have a prestige s3 2016 as well. Its in the vehicle settings for locking. You can make it so when you touch the door you can unlock all of them as well. Now my mirrors fold in when i lock the car.
    Aug 09 2015
    Southern Cali
    Thanks I'll try that
    2016 S3
    10' Gti sold
    06 A4 sold
    Sep 05 2016
    A DIY would be welcomed for those who have pulled it off!
    Apr 10 2014
    HK
    I purchased a grey oval dimming mirror from China! It is OE, you can find them on Aliexpress. Mine cost me $90.
    Came with a simple two cable harness, that is long enough to reach the fuse box.
    To remove the old mirror, take off the top trim, then twist the mirror base clockwise, it will pop off. Route out the cable and find a switched ignition and gnd.
    It should take no more than 30mins to wire up.
