So I had a random CEL for multiple misfires, showing across both banks in random cylinders at different times (leading me to believe it wasn't coil related). Initially when it happened, I took her in to get checked out, and the dealer said it was the crankcase breather valve and hoses that were allowing extra air into the chamber, causing issues. They tested it with an aerosol propellant, and showed that it was the issue. So we got that replaced. $1k gone
Drove her for about 3 weeks or so, and under the first real load I gave her, got the flashing CEL and backed off. Showed random multiple misfires so I limped her home (not limp mode, just gentle) and parked her to wait to get the scan done. Once scanned, it showed again, random multiple misfires, but this time exclusively in cylinders 1 and 5. Now I was thinking the best way to eliminate coils from the equation was to get them done. So last night I replaced them all with the red tops, part 06E905115E, purchased through the dealer through a solid connection. I unplugged the battery to clear the codes, and when I started her back up, codes were gone, CEL was gone, and all seemed well for the 5 minutes that I left her idling.
Fast forward to an hour ago, I started her up to take her to work, and heard a very strange noise, coupled with a CEL. It was repetitive, and the best way to describe it is if you make the sound "boop" with your mouth with some bass in your voice. The sound happens quickly, and repeats cyclically, almost like it is happening in connection with the spark. So I immediately killed the engine and panicked for 3-4 seconds before I cleared my head. I restarted her with my phone in video mode to capture the noise, and the sound was gone, but the CEL came on solid, after 5 seconds flashed, and after 5 more seconds stayed solid. The idle was also causing vibration in the car, slightly more than usual (my motor mounts are bad). I gave her about 1200 rpm and the vibration left, noise did NOT return, lights stayed on, but all sounded normal.
To be safe, I left her parked and took the beater to work.
My questions are:
- What the hell was that sound? I've never heard it before, and almost didn't think it was coming from the engine because it isn't one I've heard before. I really hope it isn't detonation..
- What else should I pursue to address the misfires? I was going to wait to do plugs until I got the CC done, planned for January
- It has been 25k since the last CC. Is it time?
I appreciate the support. Any constructive feedback, questions, and comments are welcomed.
-Jamil
